Limp Mode Problem
Old Apr 5, 2005 | 08:48 AM
slepac's Avatar
Car: 87Z28
Engine: 383 or so
Transmission: Hanging on
Limp Mode Problem
Hello there
Last night i ran into a problem with my rig. I have a '165 converted to '730 with an adapter harness. I was moving the computer around trying to mount it and i think i removed the memcal also in the process with the ECM under power. Since then the car has been in limp home. ECM does not register on the ALDL, I’ve burned a couple of additional chips, switched the computer, no help. My only guess is the adapter harness might have been screwed up in the process but i checked it out and it appears ok. Could the ESC/additional resistor be the problem?
Anybody have any ideas?
Old Apr 5, 2005 | 09:27 AM
11sORbust's Avatar
sounds like a loose ecm pin. get a close look at the ecm/adapter connectors, one might be slightly pulled out. Not talking about the connectors but rather the wires going into the connector....
Old Apr 6, 2005 | 07:57 AM
slepac's Avatar
Car: 87Z28
Engine: 383 or so
Loose PCM ground (DUH!!) at the MAP ground splice.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
Slush92RS
Sep 2, 2015 08:56 PM
