radio shack prom removing tool
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
does anyone have a part number or what the proper name of the tool is called to remove the prom. i asked the guy at radio shack and he was clueless......thanks
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I dont have the number laying around anymore, but it does work fairly well.
They have a little kit, one part lets u clip the chip in and install it and the other piece lets u grab the ends of the chip so you can lift it out from both ends at once.
Go to the store, all the Radio Smacks around here have it that I have seen.
edit: says 6-40pin DIP IC Inserter and Extractor Set.
#276-1581 under Radio Shack label(found the box)
later
Jeremy
later
Jeremy
thanks for the info. i will check it out and see....
i picked it up today...thanks for the info jeremy
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Originally posted by Ronny
an alternative is a ZIF adapter from Moates. press fit or solder in place of DIP socket. holds prom by spring loaded lever. less chance of bending pins on prom.
i bought one from moates already and i am just waiting for it to get here. should be here wedsday. one thing about me is that i am always in a hurry so i wanted to get it started yesterday. so i deceided that it was worth the 8 bucks to ge tthe tool anyway.
Just some clarification for the new guy.
Until u get used to it, using the chip installer will help you alot. Way less likely to damage anything.
The tool is also helpful if u use the low pro zif sockets since they have a lot smaller opening than the larger zif sockets.
later
Jeremy
later
Jeremy
i dont know which one i got from moates. he emailed me and said to use some package that comes with the adapter, zif and two chips. i am going with the ostrich anyway so most likely i will do it once and thats it. i also bought the data cable from him too to datalog.
Dialed_In
Aug 20, 2015 01:45 PM
