Adjusting timing 8746
Old May 20, 2005 | 12:36 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I currently have my timing advanced 4 degrees across the board and I just got my new radiator installed so I'm ready to max this poor 305 out. Currently I am getting zero knock on accel just a few on decel and cruise-control. I am not exactly sure how to sculpe the timing tables can I get some helpful links?
Also looking at datalog, how can I remove the I have knock?
Latest WOT dataruns
Old May 25, 2005 | 04:49 PM
Car: 91 Camaro RS
Okay if I have knock that I need to remove do I
1. Remove timing from the time in which knock occurs (ie. kc goes from 5 to 7, do I change the timing from that rpm/ map at the row with kc 7)
or
2. The row before the knock occured (ie. kc goes from 5 to 7, do I change the timing from that rpm/ map at the at the row with kc 5)
or
3. Some weird formula that really isn't a formula but gets the job done.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 21, 2015 07:20 PM
86White_T/A305
Aug 17, 2015 12:16 AM
