Tunerpro 4 Bin stacking & burn problems
Old May 30, 2005 | 04:22 AM
Siggy's Avatar
Car: 1988 Camaro IROC LB9 F
Engine: 305 HO EFI
Transmission: TH700R4
Axle/Gears: GU5 LS 3.23
Actually I have a few questions
Why I'm unable to stack and burn using a Willem burner?
Why is the Flag data given differently in Tuner (plain talk) and the RT version (Acroynums & bit info) using same bin (6E) and dif file?
Willem burner, I stacked a 6E 16k 6E bin with TP set for chip 32k, block 32k and then burned using a AT29C256 EEprom. I started with a new chip and got an error...cleared the buffer, read the chip and the buffer showed all 0's. This has also happened using a ST 27SF512 but using the correct 64/64 chip and block size. Is there anything about the stacking feature in TP4 that prevents the stacked bin from being used in certain burners ???
Another ??, I am trying to understand how to offset a 16k bin using the 29C256 and the Willem, when I burn using a 27C256 eprom I can edit a Hex offset window OK, using the 29C256 eeprom this window becomes locked...can't seem to find a way??
All response gratefully accepted.
Azrael91966669
25
Jun 20, 2017 04:04 AM
GTAman
Sep 21, 2015 09:57 AM
dyeager535
Aug 28, 2015 08:10 AM
beast94
Aug 20, 2015 06:44 AM
tmellott89
Aug 16, 2015 02:58 PM
