Prominator Vss have to be correct?
Old Jan 4, 2005 | 09:44 AM
LKJR's Avatar
This may belong in a differnet forum.
71 chevy blazer is the vechicle I"m doing my tpi swap on. the speedo isn't anywhere near right I don't think,
I"ve got to different gears and bigger tires.
I plan on using a prominator in the ecm to control the TPI setup, swapping to a MAP instead of a MAF. The Vss coming off the tranny, Do I need to adjust the gear in the tranny there to read right before I do this or will it matter?
Old Jan 4, 2005 | 01:02 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Prominator Vss have to be correct?
There are adjustments in the code for letting the ecm know what the real speeds are. While your speedo maybe off, you can tell the ecm to figure things out so it's seeing the real speed.
Old May 27, 2005 | 03:01 PM
LKJR's Avatar
didn't get any reply on the other post
https://www.thirdgen.org/techbb2/sho...hreadid=297846
will the vss listed in this post work? or is there a better one? what signal does the prominator need?
Old May 27, 2005 | 04:51 PM
LKJR's Avatar
Old May 29, 2005 | 12:40 AM
Z69's Avatar
Z69
JP86SS answered your question in the other post.....
No you want a 4000 pulse per mile sender. (4 pulse per rev)
Go to the link for JTR in the other post and I'm pretty sure you'll want a 4PAC sensor setup.
Old May 30, 2005 | 05:42 AM
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
Transmission: TCI 700R4
Axle/Gears: 12 bolt with 3:73's
here's what I run in my 71 Blazer.
Go about 1/2 way down the page.
http://www.jimsperformance.com/carty.html
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Vintageracer
Sep 24, 2017 12:34 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
Bigold4x4
Sep 28, 2015 05:21 PM
