EEProm help
Old Jun 1, 2005 | 01:03 PM
CHRISMAN2000's Avatar
Car: 1991 Camaro Z28
Engine: 350 L98
EEProm help
Hey all. I finally got all my prom burning equiptment from moates.net. After sorting out the bugs for a week (damn laptop). I've finally run into a problem where I don't know what to do.
I loaded a stock bin into the tunerpro. Flashed the prom. Then put it into the adapter. The car then runs into limphome mode. Did I have the wrong bin? I got it from the bin search. Or should I just desolder my stock one and read it?
I have a 1991 z28, 5.7and ECM 1227730.
Any help would be great.
Old Jun 1, 2005 | 03:28 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I've been playing around with my burner for a few days.
What type of chip are you buring 128K or 256K?
Old Jun 1, 2005 | 05:27 PM
Engine: 350 L98
Old Jun 1, 2005 | 05:28 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Did you make any changes to the bin and not "save" the bin before burning it?
That would cause a checksum error and do that.
And check to be sure the chip was inserted in the adapter the right way. If its a 256 chip in the adapter with extra pin holes, be sure to put the empty holes at the top where the notch should be. (chip at bottom, notch on top)
Old Jun 1, 2005 | 06:15 PM
Engine: 350 L98
I have not edited the bin. I'm just trying to get a "stock" setting. The adapter is a 28 pin zif. I made sure to have the arrow pointing towards the handle.
I'm thinking either the chip broken. Or the bins are corrupt. I have four bins so far. Two from moates and two from the bin reference site.
Old Jun 1, 2005 | 06:31 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Edit:
Oops, I see that you've got a 7730. That means 32k. Burn to 0 offset.
Next question: After you burn the data to the chip, does the verify return that the burn was successful?
Old Jun 1, 2005 | 09:39 PM
Engine: 350 L98
It does verify successful when burned. But when I verify the chip with buffer its say: Failure: verification does not match.
Old Jun 1, 2005 | 11:51 PM
Mangus's Avatar
Transmission: T5WC
Then it didn't successully verify (hence the word "failure" in the output).
Do you have a different chip that you can try?
Old Jun 2, 2005 | 12:28 PM
Engine: 350 L98
I got it guys. Thanks for your help
Old Jan 18, 2006 | 12:15 AM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
edit
rsilver
Apr 28, 2004 01:53 AM
ski_dwn_it
Oct 5, 2001 02:19 PM
okfoz
Jun 21, 2001 10:11 PM
Kevin91Z
52
Mar 31, 2001 10:59 AM
