Will 89 prom work with 86 computer?
Old Jun 13, 2005 | 09:21 PM
ChevyRacer's Avatar
Car: 86 Camaro Iroc-Z
Engine: 355 TPI
Well basically the subject.
Will an 89 prom with with my 86 computer and harness.
the differences i see are in the masks(calibration)
86 has $32 and 89 has $6E
Old Jun 13, 2005 | 09:30 PM
IroczInOz's Avatar
It will work as they both use the same ECM 165.
Old Jun 14, 2005 | 12:12 PM
ChevyRacer's Avatar
Engine: 355 TPI
so what exactly is the difference in the masks?
is 89 VATS secured would that be in the prom?
Old Jun 14, 2005 | 03:13 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
You can get a NO VATS eprom. You also have the cold start injector for 86-88 cars, you will need to disconnect that.
Old Jun 14, 2005 | 11:01 PM
ChevyRacer's Avatar
Engine: 355 TPI
i'm buying a used prom here, and if it has vats, can it be disabled at the module?
And the cold start injector. If i use my current plenum, there arn't any different sensors to my knowledge with the 86 and 89. So will disconnecting the cold start injector solve that problem?
Old Jun 18, 2005 | 09:43 AM
Rebuildman's Avatar
Car: 1990 Corvette, 1985 C-10 1979 Subun
Engine: 350, 406 HSR
Transmission: manual, 200 4r
Disconnecting the cold start injector will take care of that when using the $6e mask.
As for VATS you could use tunercat to remove it which would require chip burning but if you can do that you would not have to 'buy a used chip' so I guess that is out.
As far a disabling VATS electrically I have never tried it, but I believe you have a special key with a resistor in it. Would have to give the ecm the proper resistance across two pins is my guess.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
the_nikfive
Aug 11, 2015 02:46 AM
