basic starter tuning
Old Jun 30, 2005 | 05:39 PM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
I have just started programming my own chips.
Right now I'm running super_aujp_v2, with the knock retard added back in (hey I'm too cheap for 93 octane in my daily driver ).
I know SD isn't as flexible as MAF when it comes to utilizing mods, so what I'm wondering is, where should I start making adjustments based on the mods I have below?
Old Jun 30, 2005 | 06:39 PM
brutalform's Avatar
Try giving this a going over a few times.
https://www.thirdgen.org/techbb2/sho...hreadid=288763
Old Jun 30, 2005 | 07:25 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Part throttle VE
Get those VE tables inline and operating good (VeMaster will help with the lower end to get it driving then tweak from there)
One thing you may want to do is adjust the IAC throttle following stuff a bit if you are running the stock TB.
I had to split the difference between the original S_aujp values and the second version.
The v2 settings just didn't feel right and I found it was smoother to back them down a bit. the v2 settings were to work better with bigger TBs but I'm stuck with the stocker for now
I don't remember exactly at the moment what I changed but do a compare between the versions in TP and you'll see the ones I mean.
Then go after the AE and PE stuff later.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
customblackbird
Oct 1, 2015 04:30 PM
sahlomonic
Sep 20, 2015 07:15 PM
Magman
Sep 13, 2015 12:07 AM
Formula_88AE
Sep 3, 2015 01:47 PM
