Memcal part number?
Old Jul 15, 2005 | 04:21 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Memcal part number?
I need a memcal for a 730 ECM that I'm putting in my 5.0L auto Trans Am. Any have the number so I can order one ASAP?
Old Jul 16, 2005 | 08:47 PM
Car: 86 T/A
Engine: HSR 355
No one?
Old Jul 16, 2005 | 09:00 PM
92_ZED's Avatar
Car: '92 Z28
Do you have a chip in mind? What is it, the 4 letter code?
Al.
Old Jul 16, 2005 | 10:05 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I found this one to be the latest for a 5.0L with auto trans. Indicates its for the 700R4.
There might be a better choice, this is just what I found quickly.
Look here to find the best match to your setup.
http://www.efitune.com/broadcast_codes/
Then do a check on "gmpartsdirect.com" to find the cost. This one shows $47.50.
Old Jul 16, 2005 | 10:09 PM
JP86SS's Avatar
Also, see the "get bin" in the corner.
Click on that to download the file. It is the file that is on the memcal chip you are buying. Having that you will be able to modify and tune the settings with chip burning equipment.
Old Jul 17, 2005 | 10:00 AM
Car: 86 T/A
Engine: HSR 355
Thanks. I'm still not sure if I'll have the money to burn a chip just yet, I may need to pay someone since I need to modify VSS (from what I read) and disable VATS.
Old Jul 17, 2005 | 10:06 AM
Car: 86 T/A
Engine: HSR 355
So I buy that memcal, it plugs into the ECM, then I remove the prom on it and burn a new one? Sounds easy enough, thanks alot guys!
Old Jul 17, 2005 | 10:43 AM
JP86SS's Avatar
Not the best route, you could damage the memcal easily.
Code:
1.) Buy the Memcal
2.) Buy Moates "G1" adapter (or GP1)
3.) Install G1 into ECM
4.) Install Memcal onto the G1
5.) Burn a chip (using external equipment)
    5a.) dowload the "bin" file
    5b.) download Tunerpro (free) or TunerCat (buy)
    5c.) download the TDF, ECU or XDF definition file.
    5d.) Make your changes to the bin file
    5e.) Burn your chip
6.) Install the burned chip onto the G1 adapter.
The G1 bypasses the chip on the Memcal and puts your burned chip in its place while keeping all the other circuitry intact.
If you are not going to burn a chip, you would just install the Memcal into the ECM.
It will have VATS enabled (if it had it from the factory) and the VSS will throw an error code and put you into reduced performance if not in "limp home" mode.
Hope that clarifies the process.
Old Jul 18, 2005 | 11:12 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have a question similar to this,
On my memcal it says AXXF.
Then on the "computer" it says AXYC.
Which bin do I download to the flash chip?
Old Jul 19, 2005 | 02:00 AM
Z69's Avatar
Z69
AXYC is a 5.0 MT bin.
You want AXXF which is an AT bin.
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
