sample BIM file for ANTT bin
Old Jul 18, 2005 | 02:46 PM
bluzman2004's Avatar
I have the ANTT file in my stock computer and would like to see if anyone has done any tuning with this for a faily stock application. I wanted to see what kind of things have been changed to help out the power a little. If someone could just post a sample BIN I could look at I would appreciate it.
Thanks,
Old Jul 22, 2005 | 08:38 PM
JPrevost's Avatar
Car: 91 Red Sled
Do a search for ANLU and AUJP. Both are SD tunes. You'll find in some posts details about Volumetric efficiency. You need to do some research before hand and understand exactly what does what and more importantly WHEN it does whatever it does. Example; PE mode isn't used in open loop with the $61 mask (you're mask if you're using an ANTT TBI bin). Instead, it uses the Open loop AFR tables to come to an AFR.
What are you trying to do? Maybe I can point in you in a more specific direction if I know what you're goals are.
Old Jul 23, 2005 | 10:53 AM
yager's Avatar
Car: 1997 Jeep Wrangler
Engine: 2.2 L61
Transmission: R150/AX15/Toy T-case
Axle/Gears: 5.29
ahhh..Good bit of info I also have a ANTT and have been researching what to do etc... im working my harness at the moment (jeep swap) so ill be researching for a while im sure...
again, thanks for the tip.. im sure ive read it before but searching yeilds so much info its hard to retain it all in one pass...
InfernalVortex
Apr 20, 2021 11:31 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Jonas Earl
Sep 27, 2015 07:39 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
