run OL what happens to BLM's?
Old Aug 11, 2005 | 03:49 PM
Ronny's Avatar
ok disable CL and run open loop exclusively. now i look at my win ALDL/tunerpro rt and say i see some 124's and some 129's and all is pretty close. this was the BLM's from last run in CL. if i am nowin OL exclusively does the BLM's populate with new data that is disregarded but yet visable in datalog? and if i disconnect battery for a while(moves all to 128 right?) will the BLM's show me cells that are rich/lean of the magic 14.7 or so? so if i want to run a bit richer i can see those cells that are still 128-130 and change VE and get them all say 125? is a 125 BLM in OL about 13.7/1. i guess i could log with my WB and verify as well. as weather cools her(WI) i believe i will see all go leaner especially early morn run this fall right?
Old Aug 11, 2005 | 04:29 PM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
Set the BLM min/max to 128 when you are running open loop to ensure your old BLMs reset.
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
tmellott89
Aug 16, 2015 02:58 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
THX181
Aug 6, 2015 10:21 AM
