Pe Or Ae 808
Old Aug 15, 2005 | 01:58 AM
wake77's Avatar
Pe Or Ae 808
Does anybody know in the australian 808 $5d software how to change power enrichment i have just got my lm-1 wideband and trying to sort it out i have found it as acceleration multiplier vs rpm in the later $12 software and am going to try changing to that i just couldn't find anything for the $5d .
Thanks for any information.
Ross
Old Aug 15, 2005 | 06:02 AM
Adrian's Avatar
The F60 table looks after the open loop A/F ratio while KAETPS: AE Delta TPS AE factor and KAEFUEL: AE Delta Fuel AE factor look after the "pump shot" aspect.
Adrian
Old Aug 29, 2005 | 06:02 AM
wake77's Avatar
Adrian thanks for pointing me in the right direction but can you tell me what these figures actually do? and which way to change them
and i assume the DE factors are the same, i'm having problems in both areas when i touch the accelerator it spikes lean before it richens up. when slowing down and the DE should come in to play it actually gets richer unless the tps is low enough to go in to DFCO.
Thanks again
Ross
Old Aug 29, 2005 | 09:27 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
A lean spike can be AE or VE table related. Sometimes, at the lower pedal movements, it's hard to get the AE to ramp up as you might want it too. In that case you might want to slightly richen up the VE table in that area.
There will almost always be a slight rich spike, when you let the throttles *snap* shut. It takes an instant for the gas laying around in the plenum, and runners to vaporize, and then be consumed. If the lower end of the VE table is too rich, that will contribute to the problem.
Old Aug 30, 2005 | 10:08 PM
wake77's Avatar
Thanks grumpy but what i wanted to know was what these figures actually do. i don't know if it's how much change of the tps or just any movement of the tps and if there a multiplication factor or just extra fuel. i just don't know how to adjust them.
gunny
Jul 10, 2004 01:35 AM
Sp0nGa
Mar 6, 2004 09:36 PM
JohnL
Apr 24, 2003 07:59 AM
funstick
Jul 18, 2002 11:28 AM
