BLM tuning?
Old Aug 18, 2005 | 08:04 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
BLM tuning?
I'm curious... if I'm idling with a BLM of 118 (rich - the ecm is removing fuel to attain 14.7:1) then is this true -
118/128 = 0.921875
1 - 0.921875 = 0.078125
= I need to remove 7.8% fuel at idle?
Wondering if I'm seeing this correctly....
Old Aug 19, 2005 | 12:11 AM
Teeleton's Avatar
Car: 89 S10 Blazer
Engine: Built 4.3L V6 TBI
Transmission: Built 700R4
Axle/Gears: 7.65/Zexel/3.73
Re: BLM tuning?
118/128 = 0.921875
The easier way to do it:
Current VE Cell value * 118/128 = New VE Cell value
I tend to be a little more conservative and cut the difference in half, so it looks like this:
Current VE cell value * ( (118+128)/2 ) / 128 = New VE cell value
You end up burning more chips, but it helps keep you from making a bunch of big swings in the map if your BLMs are way off.
Teeleton
Old Aug 19, 2005 | 07:43 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Yeah, I have better luck cutting the change in half. It seems like it's too easy to overcompensate.
Old Aug 19, 2005 | 10:01 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
"Half way" moves are generally better in my testing.
Old Aug 19, 2005 | 11:20 AM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
If your not adding VE1 and VE2 first..aren't you already making less of a change?
Old Aug 19, 2005 | 12:43 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Depends upon the Mask, not all use an adder table. Doward never listed which ECM/Mask/BCC he is using.
RBob.
Old Aug 20, 2005 | 12:55 AM
Doward's Avatar
Whoops...
MAF based '302, $3A, HNL
I only have a 2D LV8 vs PW table here to go off of
Subtracting 3% (scale by .97) - lets see what happens
*EDIT*
Idles at 122 BLM now... It took a few seconds for the BLMs to settle down - they started at 140, and worked down to 122, settling there. I take it that it is because the ECM stores the previous BLMs, which, when taken with the 3% decrease in fueling, would have had the ecm 'relearn' the BLM?
Old Aug 21, 2005 | 01:11 AM
Doward's Avatar
Anyone? Without the $3A code in front of me, I can't be sure, lol.
Did a nice 2nd/3rd gear run. My AE bites right now. AFR shoots to 16-18:1 when I stab the pedal.
So I did the following -
Changed:
Accel Enrich Delta TPS PW Scale Factor from .313 to .324
Also:
Added .070 to the entire AE pulse mult vs Coolant table
I also noticed that from 3300rpm, my AFR went from 12.2ish:1 to 13:1 up to 14.5:1 @ 5000 rpm (where I let off)
So I increased my % change AFR @ WOT vs RPM as follows:
................Old values..................New values
3200...........4.3..............................4.3
3600...........4.7..............................5.1
4000...........5.5..............................6.3
4400...........5.5..............................6.6
4800...........5.5..............................7.0
5200...........5.5..............................7.4
5600...........6.3..............................7.4
6000...........6.3..............................7.8
6400...........6.3..............................7.8
Off for another datalog... we'll see what happens
*EDIT*
meh.. my neighbor's awake. I really have to get rid of this Flowmaster 40 series (WAY too damn loud!). Of course, it's 2:20am right now... I can see that he'd be a little peeved He's not really angry... Bob's pretty cool. Just flipped his porch light for me, to let me know I woke him up (little code we have - I tend to go overboard - if his porch light is on, I need to quiet it down).
Anyway, I'll report back tomorrow how this turned out. I'm also thinking I'm going to disable closed loop operation, get the fueling where I want it based on the WB (I'll be directly in control of the AFRs, with no ecm 'self tuning' going on, to at least get me in the ballpark) and then I'll go back to closed loop tuning it.
I'll be back tomorrow, with results.
Old Feb 12, 2012 | 04:44 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: BLM tuning?
I'm bringing this old dog back from the dead (much like the car it will help to repair hahahahah.)
In my beginnings to tuning, I am going to mess around with my 302 ECM and $3A stuff to learn what all this craziness means to the car.
There's a lot of good stuff here to help me out.
Mark_ZZ3
May 24, 2018 01:02 PM
