Prom question
Old Aug 21, 2005 | 03:40 PM
mgomez's Avatar
Car: '88 Trans Am/'96 Trans Am
Engine: L98/LT1
Transmission: 700R-4/T-56
Axle/Gears: 3.42/4.10
Prom question
I recently put a '89 305 TPI Auto trans PROM in my '88 305 TPI manual trans car and I'd like to get it to work. My '88 was optioned without VATS but there is a 5v wire going into the ecm where the VATS wire would normally go. I can't find an explaination for this wire anywhere in the service manual. I've unplugged the coldstart injector and the cold start sensor. I can get the engine to crank but not run. The car shows no codes and I have spark and fuel. Every now and then it will start but then immediately die. If I but the '88 chip in the car it starts right up. Everyone told me this wouldn't work but I'd like to see if I can do it anyway. I don't think the problem is VATS related but I'm really not sure. Any help would be REALLY appreciated.
Old Aug 21, 2005 | 06:32 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Burn a new PROM with the '89 code and turned VATs off?
RBob.
Old Aug 21, 2005 | 11:48 PM
mgomez's Avatar
Engine: L98/LT1
I guess that's my only solution. Now if getting the rust out of my floor pan was only that easy.
Steven 86IROC-Z
May 24, 2026 04:52 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
the_nikfive
Aug 11, 2015 02:46 AM
