aldl cable
Old Aug 25, 2005 | 12:16 PM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
aldl cable
anyone know where i can find a diagram on how to build a aldl cable for a 160 baud 1228746 ecm thats very easy to understand i can solder decently but it hard for me to understand the schematics of it.
Old Aug 26, 2005 | 11:21 AM
Engine: 305 tbi l03
please someone i really wanna start to get ready for when i buy the scanner so im not so overwhealmed tryin to learn im just tryin to get stuff togather and get familar w/ a bin i found online and all the shematics ive found are for the faster baud rate ecms....please help.
Old Aug 26, 2005 | 12:54 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
http://winaldl.joby.se/aldlcable.htm
You want to build the second schematic, pay attention to the numbers on the pins not the relative position on the plug. The schematic is drawn as if you were looking at the plug end nut the pin end that you solder to.
89C2500's Avatar
Car: 89 C2500
Engine: ZZ838, MPFI, Whipple, & 7749 ECU
Axle/Gears: 4.10
I like to use the 2 transistor design. See Rbob's responses in this post for schematics and build pictures. It works with 160 and 8192 baud ALDL comms.
Old Aug 26, 2005 | 02:42 PM
Engine: 305 tbi l03
k i just went to radio shack and got the stuff layed out in this article...http://www.techedge.com.au/vehicle/aldl160/aldl_hw.htm
will this one work for the 160 baud to datalog for mine?? or is this just some type of code scanner cause it seems much simpler than all the others ive seen? also i know this is a dumb question but like in the schematic w/ they show a line from the e or a or what ever port from the diagnostic link then show the squiggle or whatever for the resistors do i just use any kind of wire to connect the resistor to that point or do i just saulder it straight to it its hard to explain but if anyone gets what im sayin?? never built anything like that b4 just have simple solder skills and the tools to do it but never done a whole lot other than replacing messed up resistors or compacitors so if someone could make me a dummy schematic or somethin i could understand it would really help if not if u could just explain it to me in begginers language that would be great too.
Old Aug 26, 2005 | 03:47 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I have some pictures on my homepage............
/N.
Old Aug 26, 2005 | 04:34 PM
Engine: 305 tbi l03
thats a lil more what i was lookin for yeah but dont i need it to go to the aldl port e not m for my ecm?? and do i just use aligator clips or is there somethin i can use to just plug into my aldl port?
Old Aug 27, 2005 | 01:11 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
160 baud uses E instead- correct
/N.
Old Aug 27, 2005 | 09:14 AM
Engine: 305 tbi l03
so same exact design just have the clip goin to e port? thanx for all the help guys and sorry for all the questions but id hate to do everything wrong then when i get to that point nothing be working and be back at step one.
Old Aug 27, 2005 | 12:08 PM
BMmonteSS's Avatar
Car: 84' Monte
Keep in mind that you DON'T need the 10k resistor going between pin A and B. Only the TPI's with the 165 ecm need this. Other than that your good to go.
Old Aug 27, 2005 | 07:50 PM
Engine: 305 tbi l03
k can someone tell me if this one is wright cause i understand and have all the parts i need to build this one...there is only one difference though i dont have the resistor in between a and b and the 12 v is gonna be commin from the h port on the car is this right well heres the schematic to look at thanx guys just let me know if this one will work on my 160 baud 1228746 ecm $61
Old Aug 27, 2005 | 07:52 PM
Engine: 305 tbi l03
oh yeah and no r4 transistor since no carb....and ive seen schematic w/ an led can i put one on this cause i have an led already too.
Old Aug 28, 2005 | 08:02 PM
BMmonteSS's Avatar
Car: 84' Monte
You need to use the second schematic on that link that I posted earlier. It doesn't need an external 12 volt source. You also don't need the 10k resistor between A and B, just leave it open.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
