P4 memory map
Old Aug 26, 2005 | 02:47 PM
11sORbust's Avatar
P4 memory map
What exactly are these RAM locations used for?
L0042
L0043
L00C4
thanks,
Tim
Old Aug 26, 2005 | 03:56 PM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
Depends on the calibration.
Assuming AUJP:
0x0042 is diagnostic mode word 3
0x0043 is diagnostic mode word 4
0x00C4 is knock retard
Old Aug 26, 2005 | 07:24 PM
11sORbust's Avatar
Assuming AUJP:
Sorry I was talking about the arap code.
one more question, do you mean the locations vary mask to mask or that each calibration is totally different?
Old Aug 26, 2005 | 09:16 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
They usually do, and they can.
Old Aug 27, 2005 | 01:17 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The locations are the same for each mask and associated calibrations.
Old Aug 27, 2005 | 01:19 PM
Car: 88 Camaro SC
Engine: SFI'd 350
For example the $6E (and any calibration based on it) would have one set of addresses for everything, and the $8D would use different addresses for everything, and so on.
Old Aug 27, 2005 | 05:58 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Sorry, but no. For further information look at the Tunercat site, and look at the 5B series of Masks. There are 3 very different set of codes used for all three masks, that are all 5Bs. They're even used in different pcms. 8253/3247/1470, as I recall.
Old Aug 27, 2005 | 07:50 PM
11sORbust's Avatar
so aside from different hardware configurations, the mask will ususally dictate n/v memory locations(not the cal), right?
Old Aug 27, 2005 | 07:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
No, it defines the calibration layout.
RBob.
Old Aug 27, 2005 | 08:40 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Are these RAM addresses, or PROM addresses your referring to? While I dont doubt it, having different RAM addresses and code for each calibration subset for each mask seems a bit counterintuitive.
Old Aug 27, 2005 | 08:54 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Whats implied by the letter following the mask ID byte on TC's site? In the 0D there are lots of tables that are used only if TBI/CPI is in use or if a manual/4L60 (or TH400?)/4L60-E is being used. Maybe each one only includes the tables that apply? Im sort of curious now. Maybe Ill cross check different cals in a hex editor and see how much really changes...
Vintageracer
Sep 24, 2017 12:34 PM
aaron7
Sep 30, 2015 09:15 AM
tuningnewb
Sep 23, 2015 07:06 PM
ULTM8Z
Sep 16, 2015 09:15 AM
