Cylinder Volume Calculation
Old Aug 28, 2005 | 08:08 AM
EdgesZ28's Avatar
Car: 91 GTA - 94 TPI Suburban
Someone running a 383 with $8D E-mailed me with some problems and I asked if I could help him out.
I identifed two problems, knowing he was running a stock AUJP bin:
1. Injector Constant - He has 24# injectors.
2. Cylinder Volume - Set to 713 cc/Cyl
I found this cool on-line calculator that converts cubic inches to milliliters: http://www.metric-conversions.org/vo...illiliters.htm
Well, 713 cc/Cyl is actually closer to 348 cubic inches; but I suppose is close enough to not make a difference on a 350.
A lot of people run a 30 over 350. So I was wondering would running a 355 ci be affected by not changing the constant? It calculates to 727 cc/Cyl. Or is it too small an amount to really matter?
I told him to set his Cylinder Volume constant to 785 ccc/Cyl for his 383 cubic inch engine and his injector constant to 24 and make sure the pressure was set correctly.
Any thoughts on the question above? Ed www.edgesz28.com
Old Aug 28, 2005 | 05:43 PM
tail's Avatar
Car: 1991 Formula
Engine: 355 with ported & polished vortech heads and a 269 cam.
Transmission: 700R4 (w/ shift kit) and 2000 stall TC
Im running a 727cc/cyl and 24lb injectors, my BLM & INTs work real well. seems to be happy with the adjustments. Before, it would act real screwy, under compensate, over compensate, etc. Having your constants correctly calabrated makes tuning easier.
Old Aug 28, 2005 | 07:04 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
What he said....
Old Aug 28, 2005 | 07:32 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Same here when my BPWC was off with the 312 and had 9C1 injectors in it.
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
