MAF AE $6E specifically, found better throttle responce?
Old Sep 8, 2005 | 04:11 PM
JPrevost's Avatar
Car: 91 Red Sled
Accel. Enrich %BPW Factor vs. Async Pulse
That's the table name in TunerPro.
Notice the 1st pulse is 0 and the 2nd is 0.25 on most stock bins. Well I found better throttle response (noticable to me and a client) by changing the 1st pulse to 0.25 and the 2nd to 0.4 . I just thought I'd share that bit of info if it helps anybody. I think that table needs to be modified when you start dealing with faster reacting motors. This engine I was tuning had $600 worth of TPI parts, Lt4 hot cam, and headers. Everything else was stock. The car now has the ability to snap the throttle open and light the tires just as quick and then control the tire spin through throttle modulation as apposed to before where the throttle snapping open would cause a small delay and lean spike.
Old Sep 8, 2005 | 04:53 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Very simliar table in the $8D.
Wonder if that could be the same issue I am having on my tip in lean spike also...
Have to play when I have some spare $$$ for the tank.
later
Jeremy
Old Sep 8, 2005 | 10:05 PM
2new2funny's Avatar
Re: MAF AE $6E specifically, found better throttle responce?
Thanks. Will try it out.
Old Sep 8, 2005 | 10:09 PM
2new2funny's Avatar
My ARAP BIN shows 0.5 for all 8 values.
Anybody else?
Old Sep 9, 2005 | 12:00 AM
JPrevost's Avatar
Car: 91 Red Sled
Anybody else?
ARAP = Y-body bin. I should have been more specific and said stock f-body bins.
Old Sep 9, 2005 | 12:41 AM
Z69's Avatar
Z69
Thanks for the info JP.
Every little data point helps make the picture become clear.
Old Sep 9, 2005 | 09:28 AM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
Agreed!!! Do you by chance have all your 6E code information all stored in one location so you could post it in the stickies section?????
Old Sep 9, 2005 | 09:59 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
How does the car run?, it's what makes the engine happy, that counts. A tip-in leaness isn't necessarily bad, if there's a lag, orthe plugs are showing signs of pre-ignition then that's what counts.
Old Sep 9, 2005 | 11:18 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
FYI,
The AUJP $8D table at 53B has the first point at 3.98 and then filled with 0.500 for the rest of the way.
Mark_ZZ3
May 24, 2018 01:02 PM
amargari
Nov 10, 2015 02:09 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Nick McCardle
Sep 10, 2015 08:36 PM
