$60 tunerpro R/T def file, ATTN: RBOB
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I bought an ostrich from Craig today (ordered), and will be trying it as soon as it shows up. I have a registered version of TunerCat but I wanted to Try tunerpro out.
I noticed there was no $60 definition for Tunerpro, and well, I've been using $60 for sometime now.
I made a few changes to Rbobs $58 def file from Craigs Fileman site in the address area and it seems to map out the 32k bin image and calculate checksuim properly.
If Rbob doesn't mind me distributing it, and anyone would like to try it out lemme know.
Once/If Rbob approves, I'll upload the modified version to Craigs site, and my own.
-- Joe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: $60 tunerpro R/T def file, ATTN: RBOB
-- Joe
-- Joe
-- Joe
Car: check
Engine: check
Transmission: check
-- Joe
-- Joe
RBob.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 91 Red Sled
Re: Re: $60 tunerpro R/T def file, ATTN: RBOB
Originally posted by RBob
No problem with putting it on Moates and your site. As for a file name, maybe 60RRJA01.ECU? Using JA as your initials and 01 as the version. Can even put an 'updated by xyz' at the end of the file (I'll leave the actual wording up to you).
RBob.
RBob.
. I like xdf, I like it a LOT. Thread
