Melted my skin to the prom!!!!
Subscribe
Sep 16, 2005 | 09:02 PM
ya that's right, my Camaro took some skin tonight ....
i was in the garage and i set my chip to 1,250rpms ... but its always been at 1,500rpms at idle so i tryed agin and i ran it and everything seemed fine till it automicley increased the rpms and was sitting at 2,000 rpms... the check engine light stays on all the time
and i know if i put the chip in wrong it flashes nonstop anyways after i shut the car off, i went to switch the chip and i lost my skin and have a really BAD burn mark....
then i let the ecm cool down and put another one in
started it up and same thing got hot with in 10sec.... i have no clue whats going on
Reply 0
Sep 17, 2005 | 01:42 AM
no ideas?
Reply 0
Sep 17, 2005 | 06:28 AM
This will happen if VCC and ground are reversed. You are probably installing the chip backwards.
RBob.
Reply 0
Sep 17, 2005 | 07:58 AM
man glad i looked in this thread i was under the assumption that u could not install the chip but one way...i didnt think the pin headers would line up correctly, yet another thing i will have to keep in mind.
Reply 0
Sep 17, 2005 | 02:40 PM
well, if the check engine flashs non-stop when the key is in the on position, witch means the proms in wrong cuz it cant find it....
Reply 0
Sep 17, 2005 | 04:47 PM
this is the way its in when it flashs non-stop, i read that when it does that it cant find the prom....
Reply 0
Sep 17, 2005 | 05:56 PM
Quote:
EDIT:
That is correct way. check here: http://www.moates.net/documentation....entation_id=10 You must have a bad chip or soldered something wrong.
Reply 0
Sep 17, 2005 | 07:26 PM
Re: Melted my skin to the prom!!!!
You have a 256K prom shown in your pic, and it looks like you're using an ecm that normally had a 4K prom.
You need to have the .bin loaded in the right area of that bigger prom for the ecm to see the .bin file.
What ecm are you running?.
The Moates link refered to by someone else is for the G1 which is for another series of ecm then the one you're using.
If the SES acts screwy immediately turn the key off!.
Before you start the car with ANY new prom, be sure to just turn the key on, and wait for the blink on, off, and on again. If the SES doesn't do that DON'T start the engine.
Reply 0
Sep 17, 2005 | 07:28 PM
no ideas?
Lots of ideas, but a limited budget.
Reply 0
Sep 18, 2005 | 01:01 AM
Re: Re: Melted my skin to the prom!!!!
i staked the bins making it a 4k, im using a g2, this is confusing as hell....
Reply 0
Sep 18, 2005 | 01:03 AM
the chips still work.... so in the pic thats thee wrong way.... but iv put it in the other way witch seems the right way the check engine light stays on all the time.... im reallly counfuesd
Reply 0
Sep 18, 2005 | 01:06 AM
its for my 8063 ecm
Reply 0
Sep 18, 2005 | 01:16 AM
so ya now im really confused.... the way i had it with the light on is the way i was spose too but then why is the chip ready to bust out and meailt.... the chip still works i can load and save off of it.... i have 2 and the other one same thing.... so could some like gide me i think this really sucks ***.....
Reply 0
Sep 18, 2005 | 05:25 AM
How's the soldering work? If you want to send me the ECM, I'll have a look at it and see if I can get it right.
It sounds like you have some traces crossed or shorted where they shouldn't be.
In the picture shown, the chip is facing the correct way (notch toward middle).
Reply 0
Sep 18, 2005 | 09:27 AM
The way you have it shown in the picture, is the correct way.
You might take Craig up on his offer to inspect what you've got.
FWIW, my success rate is 1 for 7 on doing any ecm soldering, it's more difficult then it looks.
Reply 0
Sep 19, 2005 | 02:51 AM
lol What Bruce said :-)
ECM work isnt fun and really hard on us normally blind folk.
I am 2 for 2 on ecm and 1 for 1 on a memcal :-)
Both ecms and the memcal were completely done and assembled and then torn apart and resoldered again to make them actually work right :-) Second time was thankfully the charm and a lot more time later they ended up working.
If u dont have someone with electronic etc background to test it/check it, send it to craig for a looksie. He's a good guy to deal with
later
Jeremy
Reply 0
Sep 19, 2005 | 09:18 AM
Yeah, I've been getting pretty good with them now. Most of the retrofit stuff looks like it came that way from the factory now when I get done, unless it is a scarred-up rework
Reply 0
Sep 23, 2005 | 08:05 PM
ok witch way do i stack these, im just going to re soader them agin make sure everythings right
Reply 0
Sep 23, 2005 | 09:14 PM
Just like you've got it, assuming the pic of your ECM isn't misleading. Check here for more clarity:
Reply 0
Sep 24, 2005 | 02:59 PM
does the base part thats spouse to be soader to the prom board matter witch way that gos? the buttom board in the pic....
Reply 0
Sep 24, 2005 | 05:05 PM
I'm sorry, but you might need to restate your question. I'm not sure I understood precisely what you were asking.
Reply 0
Sep 24, 2005 | 08:58 PM
does this matter witch way it goes?
Reply 0
Sep 24, 2005 | 11:29 PM
No, but place it such that the notch is pointing inward.
Reply 0
Subscribe
