Newbie need ALDL help
Car: Caprice wagon
Engine: 5.7TBI
I have the ALDL cable and WinAldl. I hooked it up to that car this morning. The RAW data comes right up. It doesn't seem that the rest of the spark counts ,etc. show up. I have a 92 Chevy Caprice Wagon with a 350TBI that I am working on. I used the 1228746 code as reccomended by from TBIchips.com.
Also, on the top of that page where the little "box" is it kept flashin 23. Does that mean anything??? Can comeone read the data by any chance? I'd like to figure this out. I called Brian today and his machine says he's gone to the 27th.
I can email the blm and log just in case! THANKS.
DJ
DJ
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
the number is the number of items in the data stream IIRC.
Should be working fine if you have a number there.
Car: Caprice wagon
Engine: 5.7TBI
The number there is the "23". It shows the raw data just fine still. It doesn't show ANY info on all the other test tabs.(02,sensor,etc) Is there a reason why or any ideas???? Also, is there somewhere I can find what data each should have? Like where the number range should be?? Thanks.
DJ
DJ
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
You need to use the 16144288 in WINALDL for it to work properly, not the 8746.
IIRC the 8746 is for TBI Bcars from 88-90 ('brick' Caprice).
The 16136965 (6965 for short, as used in the 'whale' 91-93 TBI Bcars) requires the 4288 in WINALDL. HTH.
Car: Caprice wagon
Engine: 5.7TBI
IIRC the 8746 is for TBI Bcars from 88-90 (brick Caprice).
The 16136965 (6965 for short) (used in 91-93 TBI Bcars) requires the 4288 in WINALDL. HTH.
DJ
rubblerubble
Mar 13, 2016 06:57 PM
