true DOS based aldl data log?
Old Sep 30, 2005 | 12:24 PM
thomjpster's Avatar
Car: '68 jeepster
Engine: 340
Transmission: th400
I've searched and I see that the Palm datalogging is "in the works" BTW I've got a m130 os ver 4.1 just waiting for a shot at my 7477
So, is there a true stripped (B&W) DOS version of winaldl available?
I've got a HP 200lx, "real" serial port, Dos ver 5.0 that I was thinking I could use
Possible? I did have autocad light running on it for a while
Thom
Old Oct 1, 2005 | 05:15 AM
JohnL's Avatar
I think one of the DOS freeware programs is "Carbytes". There used to be a copy on the FTP site.
John
Old Oct 2, 2005 | 01:07 PM
Vader's Avatar
I have an old version of AutoTap that came with a DOS application as well as Windows.
Old Oct 2, 2005 | 06:31 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
Craig Moates has a DOS version of an ALDL scanner that I still use today
visit www.moates.net
ECM852
Old Oct 4, 2005 | 06:21 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
I second the Moates software -- and its free. The best part is he gives you the source too, so you can fix broken stuff (if there's any left) or customize it to your liking.
Old Oct 4, 2005 | 09:03 AM
thomjpster's Avatar
Car: '68 jeepster
Engine: 340
Transmission: th400
Sweet,
Thonks guy's, I'll give it a go.
Thom
Old Oct 4, 2005 | 10:46 AM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
I also like the Moates' software -- but it's only for the '165 and '730 ECMs, not the '747. So, I'm not sure it's the answer you were looking for.
AutoTap is only for OBDII, even the old DOS version.
Diacom might be an option, if you can find it used. New, it's overpriced enough that I'd suggest spending your money on a better laptop to run WinALDL or TunerPro RT instead.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
TheExaminer
Sep 6, 2015 11:40 PM
Amillionoh7
Sep 5, 2015 11:44 PM
