1227747 TCC 4th Gear Input Question
Car: 1983 G20 Chevy
Transmission: 4L60
It seems that I read a while back that you can check a bit on the 122747 to invert the TCC switch. Am I on base? Seems that when I dropped the pan to change the switch, I put the wrong one in. On my datalogs I am in 4th gear in every forward gear except of course 4th gear. The switch is backwards from the one I needed. Don't care to take another transmission fluid bath and spend $20.00 on fluid, if I can get around it by burning a chip.
dhonda200
Aug 11, 2015 11:50 PM
