Emulating w/o aldl data?
Old Oct 24, 2005 | 07:43 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Though familiar with data logging, I am new to tuning. I have the Autoprom USB w/ the G1 package. I can datalog and emulate independantly, but not toghther...which seems to be the norm.
What is the purpose to emulating if you cannot varify the results through aldl data? Or is it pretty much pointless unless you are simply trying to smooth your idle or something on an equivelant level?
This is in respects to a '730 and tunerpro rt. Am I missing something, or will I have to run another datalogging program while tuning w/ tunerpro?
Old Oct 24, 2005 | 10:31 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Should be able to do both, no problem.
Setup TP to be in AP mode, which it should be if you can emulate.
Load up a good ADS definition file for the ALDL and you should be set.
You need to click "select log file..." button and create a file name to call the recorded data.
Press "connect to ECM" then hit the record button to capture it.
If you have an older laptop (or a good one) with a serial port you will also have the option to run another logger from that port while emulating on the USB.
I've done it both ways with good success.
Falcon50
Aug 22, 2020 03:26 PM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
bjpotter
Oct 4, 2015 07:48 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
greenyone
Sep 8, 2015 08:41 PM
