Re-pinning?
Old Nov 8, 2005 | 05:09 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Re-pinning?
Did a search, and didn't come up with anything... Don't want to tear up my connectors, so does anyone have a good site/thread with a nice explanation as to exactly how the pins of the ECM connector are supposed to come out??
Old Nov 8, 2005 | 05:50 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
What is the original ECM? What is the ECM that is being installed in its place?
Old Nov 8, 2005 | 05:57 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Re-pinning?
There are special tools available for removing them, it's a square *probe* with a slightly wedge shape to it.
There is the ecm pin side of the cavity, and then the blank side, insert something into the none ecm pin cavit and press it to the side, to release the *catch*. If you get to a junk yard, and snip one out, and then yank one *pin* out, it becomes obvious.
Old Nov 8, 2005 | 06:25 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I use one of those small jewlers screwdrivers. Flat blade about 1/16". Just push into the little cutout/slot in the connector next to the pin in the connector.
It's just a little flap of metal sticking up from the ECM pin to keep the pin from being pushed out twards the wire side. Slight pressure on the flap to push it down to the level of the flat part of the pin and it will slide right out.
Old Nov 8, 2005 | 06:37 PM
Doward's Avatar
Ah, gotcha, thanks!!
1277302 to 1277730 + $58 code
Old Nov 8, 2005 | 07:34 PM
midniteplowboyy's Avatar
Car: 91-Z28
Engine: SLOW ONE
Lisle Terminal Tool, P/N 14900
Fits most, if not all your cars connector pins, worked great on my repin, and haved used it several times on other connectors IAC, etc.. Cant remember the cost, but worth every penny to me, for my tbi to tpi, hopefully soon for my swap to the 749, as soon as I get my turbos installed.
Old Nov 8, 2005 | 08:45 PM
JPrevost's Avatar
Car: 91 Red Sled
I use whatever is closest to me at the time. Needles, small screwdrivers, safety pin bent back, small paperclip. Anything that'll get in there and push the latch so the pin slips out . No need for a fancy tool, just have some fine motor skills.
Old Nov 8, 2005 | 11:40 PM
junkcltr's Avatar
Engine: 3xx ci tubo
mechanics wire ground slightly flat on one side. Small enough with plenty of strength.
LegacyThirdGen
Aftermarket Product Review
Jul 28, 2015 08:23 PM
timfitz63
Apr 6, 2013 06:59 PM
1991_RS
Feb 24, 2013 04:23 PM
adamwbennett
Mar 25, 2010 02:46 PM
92GTA
Apr 23, 2003 01:25 PM
