Looking for a memcal adapter
Old Dec 18, 2005 | 10:32 PM
racingdragracer's Avatar
Car: 1969 camaro
Engine: 90 TPI
Transmission: 400turbo
I am looking for the homemade adapter that you use to put the whole memcal on a programmer to program the chip.
Has any body got any.
Digi-key wants something like12 to 18 dollars for shipped.
Its the little blue connection header in the prom intro on traxions page.
Old Dec 18, 2005 | 11:54 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
www.moates.net
/N.
Old Dec 19, 2005 | 01:41 PM
brutalform's Avatar
Does Craig carry those? When I was getting the tools together, the only place I found the "header" was at Digi-Key. I bought 2 of them, just in case I messed one up.
I did get a G1 adapter from Craig though.
Old Dec 19, 2005 | 02:15 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
why take out the whole memcal when you can simply install a zif socket on the memcal and just leave it in place?
Old Dec 20, 2005 | 04:46 PM
brutalform's Avatar
I believe racingdrag racer is talking about the blue plastic header, that must be modified, to use on a memcal. I only use this piece to "read" a eprom, as it is still soldered to the memcal. This is an easy way to connect it to a programmer. If I am wrong, please correct me.
The easiest way, IMO, is to purchase a G1 adapter, and an Aries ZIF socket, and a few EEPROMS, (AT29C256), from him also. The G1 allows you to plug your original memcal onto it, and "bypass" the original prom. You will still have your limp mode, and ESC, etc. This eliminates an eraser, as you can re-write over the EEPROMS, (Electronic Erasable). This way you can simply flip the handle on the ZIF, remove the EEPROM, and place it in the programmer, program it, then reinstall it in the ZIF, which is installed on the G1.
IMO, it does not get any more simple than that.
Old Dec 21, 2005 | 08:00 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
if you want to just burn a chip already installed on a memcal, you can use a piece of wire-wrap dual .1" header material, clipped down to the right number of pins, and plugged into the memcal. with the wrap headers, the leads are over 1" long, so you can spread them apart to fit into the programmers ZIF socket, usually. The part is super cheap, though you might have to get it from digikey or mouser, I don't know if radio shack carries it.
I'll ty and dig up a picture of what I'm talking about. Not having much luck right now with it.
Old Dec 21, 2005 | 09:04 AM
Car: 1969 camaro
Engine: 90 TPI
thanks guys but I got a hold of Craig Moates. As expected he has everything.
He has one it is called a HDR1. I ordered it from him. 10 bucks.
I say thanks again.
InfernalVortex
Apr 20, 2021 11:31 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
lethaldomestics
Sep 21, 2015 01:18 PM
