Truck ECM
Old Dec 20, 2005 | 12:23 AM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Truck ECM
If any of you have noticed the Weiand 144 is for the truck TBI.
Is the truck ECM a bolt on to our cars? (Wont need harness changes)
Old Dec 20, 2005 | 12:31 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I might be able to answer your question! I use a 1992 Van harness in my Van which used the 299 ECM. The pinout of the 299 is the same as the 1227747. The major stuff is the same. I only added 2 wires when running the 8746 car ECM (1990 Caprice 9C1 ECM). That was the IAT sensor and the Power Steering Pressure Switch. Everything else was a direct swap.
Old Dec 20, 2005 | 09:12 AM
crrllmich's Avatar
Engine: L03, LS1
Think its easier to tune the truck ecm over the 747?
Shouldn't the weiand 144 be a direct bolt on once the conversion was done?
Old Dec 20, 2005 | 11:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Also note that there is going to be a boosted version of the EBL code. Been running a 2-bar MAP on the ElCamino for several days now. . .
RBob.
Old Dec 21, 2005 | 02:44 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
You're killin me..................
Doc and the lil guys have already done a etch-a-sketch workup for both a single and dual turbo setup for the *truck*...
thunder57
Nov 7, 2015 02:28 PM
2012sergen11
Oct 13, 2015 07:38 PM
customblackbird
Oct 1, 2015 04:30 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
86White_T/A305
Sep 21, 2015 05:28 PM
