Searched but no answer about eprom?
Old Jan 7, 2006 | 10:16 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I picked up a 7730 out of a late 80's early 90's corsica.
Obvously it does not have the correct eprom/memcal.
My question is:
1) I was thinking of using this as a possible bench test unit with a prom adapter etc. Is it really necessary to have the limp home part of the memcal correct for the application if it actully is not in a car and just using it to test my v8 stuff?
2) I was also tossing around the Idea of using the WB patch and input for recording WB readings from a non computerized application. Is it possible to supply the power/ ground to the ecm so I can record the WB input (versus having to purchase a 250 auxbox from innovative?)
Tom
Old Jan 7, 2006 | 02:54 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
1) for the bench no big deal not having the correct limp calibration. Ground pin 56 of the MEMCAL and the code will see it as a 8 cyl. This will eliminate the cyl select DTC.
2) don't see why not. I've done a lot of ALDL testing with nothing more then B+ and ground on a '730. Just be sure to get both the IGN+ and the BAT+ wired to it.
RBob.
Old Jan 7, 2006 | 03:18 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Thanks for the input RBob!
F-body-fan
Jan 12, 2023 01:49 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
