headers , tuning, and you
Old Jan 16, 2006 | 01:57 PM
crazymex83's Avatar
Car: '88 Firebird Formula 350
Engine: L98 TPI 350
Transmission: 700R-4
I have a question that I would have to guess is programming related. Basically, would it be necessary to alter the programming on a vehicle that has speed density on it after installing headers? What happens if the headers are added without changing the programming? Does the motor run rich? I am curious what would be involved when I put headers onto my firebird. I've heard that the MAF systems will compensate for it but the SD systems will not. Thanks for the help!
Old Jan 16, 2006 | 02:10 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Volumetric efficiency goes up, so you would probably run a touch lean, especially at higher rpms. I'd be surprised if you really had to touch the spark though.
Old Jan 16, 2006 | 06:08 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
The stock calibration begins on the rich side of things at full throttle by quite a large margin, so I wouldn't worry about it. The stock cam doesn't have much in terms of overlap, either, so there isn't much gain in terms of "tuned" exhaust. It's basically freeing up some pumping losses, and having a less dilluted charge in the cylinder.
Some people have problems with closed loop at idle with a single wire O2 sensor though - runs a little bit cooler in a header. Might consider running a heated sensor.
And BE SURE you have NOOOO leaks anywhere - gasket at head, collector, etc... Those will cause more little problems than anything else.
Old Jan 16, 2006 | 08:50 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
When I added headers to my IROC with a MAF engine, it ran quite a bit leaner. I had to adjust my MAF tables and some other stuff to get my BLM's back down to 128. It was enough of an impact to notice with a scan tool, but not knowing where you are at, might not notice anything in driveability.
But like RedGold said, the stock cal is on the rich side, so you should be ok. Cant really comment on the Speed Density setup.
But I did install a heated O2, since I was going out of closed loop at idle.
z 28 jari
Sep 14, 2021 10:03 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
89fast5oh
Sep 8, 2015 09:55 AM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
