Problems with getting first chip to work HELP!
Old Jan 21, 2006 | 06:31 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
Yes ive searched, and i have the actual burning of the chip down to a process: load buffer, set offsets, verify blank, program, verify
Equipment: Burn1, G2 adapter, ZIF socket, AT29C256 flash chips
ECM: 8746
So heres the deal i have the whole thing setup and i have all the drivers on the programmer set correctly and the device works, the chips burn, and i know they work because i can read the chips into the buffer, when i open the bin in the hex editor the bin is located at the very end of the chip: from 007000--->007FFF... i put this into the car... didnt work
Now i assumed that maybe this isnt the correct offset, so i stacked the bin 4k bin, 8times, = 32kb in tunerpro to a new file, uploaded that file to the buffer and burned that, verified and tried to run it in the car... didnt work
Now should i be leaning toward maybe the ECM i have the G2 on is a faulty ECM? I am rechecking my soldering of the adapter into the ECM right now and everything looks fine... so if anyone has any ideas for me im basically pulling my hair out over this trying to get this first chip to work.
EDIT: I checked over the way my father put the g2 into the ZIF and it was 1 pin off... i made fun of him for a little bit for it haha im super stoked and cant wait to tune this thing completely... should be badass
Old Jan 21, 2006 | 08:01 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Are you installing the prom correctly into the ZIF or DIP? Can you post a pic of the prom installed in the g2 adaptor.
I didnt see that. You are putting the G2 into the ZIF and not the ZIF into the G2?
Old Jan 21, 2006 | 08:15 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Someone like dimented or Jprevost might chime in since they are TBI guys. The only other info i can offer is info from the pictures on Moates.net with the G2 installation.
1) The side of the G2 adaptor that has the resistor should be facing the other IC chip on the daughter board.
2) The side of the G2 adaptor with the resistor should be overhanging the the PCB.
3) The AT29C256 chip should have the "notch" and/or the white triangle pointing pointing to the side of the daughterboard that contains the other IC chip.
If you know all this, then im sorry. Just trying to help b/c you seem to have the burning part right.
good luck
Old Jan 22, 2006 | 02:23 AM
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
yep, it works... me and prevost have been workin on the tune, now i have the chips and i can work on it by myself... i have the working bin on the chip and in the car and its running... tomorrow will be a day of datalogging and making changes
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
Fronzizzle
Aug 9, 2015 01:15 PM
