whats the best place to learn about burnin "730"
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
hi i know there is a crap load of places to start lookin to start learnin about how to burn tune my motor, but there is just to much info and i have no idea were to start. im been lookin throught sooo much stuff the past few days im gettin lost in all the "lingo" and info!! i have a 91 730 motor in my truck with a bigger cam/highflow tpi setup/ exhaust ect and right now all im lookin for is the 101 on burnin. im lookin to run the Tunnerpro rt and ostrich or burn1. im a newbe to this big time and so i need to start very slow and go from there. thanks for your help in advance!!!
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Well these two threads helped me get started long ago. Hopefully they'll do the same for you.
The first link should give you an idea where to start hardware wise.. burners, chips etc.
https://www.thirdgen.org/newdesign/tech/promintro.shtml
The second tells you how to go about your tune. Very good article by TRAXION.
https://www.thirdgen.org/techbb2/sho...threadid=39254
The last one should help you with any questions along the way...
https://www.thirdgen.org/techbb2/sho...hreadid=288763
Hopefully this helps. Happy tuneing.
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Pac J
May 17, 2020 10:44 AM
