7749 xdf
Old Feb 2, 2006 | 11:14 PM
ihscout's Avatar
7749 xdf
the 2bar &3bar xdf show a cyl select value of 10 for a 4cyl
but this cause the aldl info to read 5000rpm at idle
i scanned a 2liter turbo bin and it showed a value of 80
aldl now reports correctly
i also notice the timing tables 2bar vs 3bar are inverted on the rpm scale
ive been working on a international harvester 4 cyl in a scout
w/mpfi and turbo
thanks for the wonderful site with tons of info
Old Feb 3, 2006 | 01:37 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Not sure if your asking a question or saying thanks for this site?
lol
Looks like you got yourself a neat looking project going together there.
Good luck
Jeremy
Old Feb 3, 2006 | 11:05 PM
ihscout's Avatar
just stating errors ive found
although if someone would like to verify if i am correct,
i wont take offense
i know most people are using this ecm on v8s
and would not be affected by the cyl select error
Old Feb 3, 2006 | 11:23 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
What is the filename and where did it come from?
Old Feb 4, 2006 | 12:42 PM
ihscout's Avatar
http://www.nwstp.com/
SyTy ECM Def (2/3 Bar)
(For TunerPro 4.0) (4/12/05
also found this hac doc for aybn .bin which states the cyl select as 80
* ECM P/N 1227749
* MY 92 Z79 T1 CYCLONE/TYPHOON TURBO LB4
* DATE 11-14-1994
* ECM P/N 1227749
* THIS ECM FROM 87 -> 90 PONT/OLDS
* SUNBIRD/CUTLASS 2.0l 4CYL TURBO
ORG $4000 ;
LC000 FDB 3971 ; EPROM ID
LC002 FDB $0A51 ; PLATFORM ID WD 1
LC004 FDB $048B ; PLATFORM ID WD 2
LC006 FDB $D634 ; CHECKSUM
LC008 FCB $58 ; EPROM ID BYTE
LC009 FCB $C0 ; NUMBER CYL'S (0 = 8)
; 4 = $80 1000 0000
; 6 = $C0 1100 0000
; 8 = $00 0000 0000
Old Feb 4, 2006 | 11:16 PM
junkcltr's Avatar
Engine: 3xx ci tubo
I don't know if it has been updated, but the last I knew the BPW was inverted. Might want to take a look at that also.
Old Feb 8, 2006 | 10:12 PM
skwayb's Avatar
Car: 93 GMC Typhoon
Engine: 4.3L V6 Turbo Charged
Transmission: 4L80e
Keep the errors coming... I want to get all the errors out of the xdf that ty1295 and I made.. but since most people were using rbobs ecu file.. I haven't put much time into it. But I would like to get all the errors out of it since rbobs is only for 2 bar and I run 3bar. So keep posting errors you find..
thanks
ZZ42Fast
Aug 30, 2015 02:39 PM
tmellott89
Aug 16, 2015 02:58 PM
jonesy
May 17, 2005 06:17 PM
JPrevost
Jan 20, 2004 08:56 PM
Bob Wooten
Apr 20, 2001 02:13 PM
