Reference Pulses
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Reference Pulses
Can someone please explain to me what exactly a referense pulse is on our car. Also, can someone explain what sends them, how they are sent and how are they recieved.
Thanks, Brian
Also, what is a Crank Pulse?
Thanks, Brian
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
The referance pulse is generated by a magnet inside the distribitor. The ecm uses that information to determine spark timing, and fuel delivery.
Car: check
Engine: check
Transmission: check
Originally posted by 91GTABird
So theoretically the ECM presumes the location the crank is at?
RBob.
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Thanks guys.
So is the Ref. Pulse and the Crank Pulse the same thing?
ie: Super_8Dm.xdf
*Enrich Accel Ref Pulses (Asynch)
*Crank Pulse Width Vs. Temp.
ie: Super_8Dm.xdf
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
No, a reference pulse is just a reference signal on a wire from the ignition module. A crank pulse is a fuel pulse width of injector on time.
The asynch stuff is a number of injections things.
