DRAC module required
Old Feb 5, 2006 | 06:16 PM
ben73's Avatar
Guys,
To complete my '8625 and 4l60e swap, I need a DRAC module..
They are not available in this country... Does anyone have one collecting dust?? I can pay via paypal in US dollars.
Thanks..
Old Feb 5, 2006 | 08:02 PM
87tpi7749's Avatar
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
In these situations, I use a digital pulse convertor from Dakota Digital, it is fully programable. I've used three of them in conversions. You are never limited to one tire size or gear ratio. Its an SGI-5. http://www.dakotadigital.com/index.c...rod/prd126.htm I'm not advertising these or endorsing them, I have simply used them with succcess, if anyone else is making these, I am not aware.
Old Feb 5, 2006 | 10:26 PM
ben73's Avatar
Thanks for that alternative. If I get stuck, I'll look into it.
Here is some info and a nifty calculator to alter the DRAC's ratio's in case you weren't aware...
http://614streets.com/drac.html
Old Feb 7, 2006 | 05:38 PM
ty1295's Avatar
I have that Dakota one here for sale.
From the info their tech support told me on the phone it does not output the needed pulses for E trannies. Well tech told me it might but will be very noisy.
So I went with GM drac module.
If someone has gotten that Dakota to work with E trannies I would be interested to know how.
Old Feb 7, 2006 | 06:23 PM
87tpi7749's Avatar
Engine: 5.7L
I had a "noise" issue with the 1st one I used, solved with a 1A diode on the ground side. Now I use a diode on the ground side all the time.
Old Feb 8, 2006 | 03:43 PM
ty1295's Avatar
What switch setting did you use and what output terminal?
Be interested as it would save me some work.
Did you run the diode from signal to ground?
Old Feb 8, 2006 | 06:36 PM
87tpi7749's Avatar
Engine: 5.7L
Switch settings and output terminals are all based on input sig type and desired output, then calibrated to get exact. I run diode on ground (batt neg) input to device.
InfernalVortex
Apr 20, 2021 11:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
