mixute LED bar coming from ECU?
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Hey all, was floating around the net, and I came across this add on rich/lean LED bar that is tapped right into the factory ECU. Just wanted to get some input on this. Could it be built DIY?? Just though it was a nifty idea. visit this link http://www.waltech.org/21stcenturyho...mixmeter.shtml
Engine: Many
Transmission: Quite a few
Yep, sure could build it yourself. Its just a typical LED driver circuit, that they hacked into an ecm, on the output side of the O2 signal amp.
I beleive Joby posted a schematic before, I think its a National Semi. LM3914? then check ludis' site for your ecm schematics, and tap into the output of the O2 amplifier, where ever it is on the main board. You'd have to check out the signal to see what the nominal voltage is, to set up the swing of the LED's
that being said, the narrow band O2 sensor meters aren't very useful, other than watching them swing back and forth; meaning, you can't really tune by them accurately.
Car: 82 Corvette
Engine: 350 CrossFire
Bill and I have an AF meter that follows the non-linearity of the stock sensor. We sell kits as well as just the bare board.
Take a look:
https://www.thirdgen.org/techbb2/sho...hreadid=237392
Take a look:
Transmission: 2004R
That is cool, I'll PM you later, I am interested in something like this, it'll go niceley with the Wb I am gonna get in a few months
Car: 82 Corvette
The WB is somewhat linear by comparison - you could actually use our same PCB but use LM3914's instead of LM3915's and it would work with the WB.
eightsixseven
Dec 16, 2024 01:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
NBrehm
Aug 5, 2015 07:57 PM
