How do i burn these chips?
Old Feb 21, 2006 | 07:05 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
Ok- Im new at the Prom burning and for my setup, i need to order a Moates GP1 adapter and zif, this comes w/ 2 Eproms. But unlike the 27C128 which is the stock Eprom, or the 27c256 these are
27SF512's. How do i set up my program to burn these proms for my 86 IROC automatic that has a 358ci built engine in it?
The package im going to order from Moates is-
Product Description: This package is very popular. It comes with two 27SF512 chips, an 'S2' ZIF socket, and a G1 adapter! This is everything you need for TPI/etc chip adaptation. If you want different chips or different socket, just purchase the pieces separately from the other items listed.
So I dont know if i should order the adapter and the zif and then order the Atmel 256 chips separately or what?
Thanks!!!
Old Feb 21, 2006 | 10:58 PM
Z69's Avatar
Z69
Do a search on bin stacking.
I've never done it or I'd tell you how.
But there are two ways.
Load the bin to the correct address or stack the bin to fill the chip. I thought Craig had some info on his site?
Or is it in the help section of TP?
Old Feb 21, 2006 | 11:45 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Z69, i think its in both places, but it seems like it was a little hard for me to understand just how to do it as i was new to Prom burning, i learned from Mark's site.
indirocz28, on bin stacking look here,
https://www.thirdgen.org/techbb2/sho...hreadid=346678
Old Feb 22, 2006 | 07:16 AM
indirocz28's Avatar
Car: 1986 IROC Z-28
OK- Thaks guys!!!
Old Feb 22, 2006 | 10:26 AM
Ollie8974's Avatar
Car: 1979 Zcode TA
Engine: 220hp 400ci Building a EFI 455
Transmission: 4 speed
Get the G3 adapter with the Ostrich, you can put 16 files on one chip
Old Feb 22, 2006 | 12:39 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
this is a budget project.. lol- i dont have the $$ to buy the Ostrich..
Old Feb 22, 2006 | 02:29 PM
Ollie8974's Avatar
Car: 1979 Zcode TA
How are you going to program the chips? You will need more than the GP1. You will need a Pocket Programer of some other similar device
Old Feb 22, 2006 | 04:21 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Umm- Tuner Pro and a eprom burner/ eraser..
what all does the ostrich do?- does it connect via ALDL and allow me to do thins while its in the car??
Old Feb 23, 2006 | 08:32 PM
DENN_SHAH's Avatar
as far as i know the Ostrich does not plug into the ALDL connector.
it does plug into your ECM & replaces the PROM, with your laptop hooked up to it, you can change things in the bin & upload the changes to the Ostrich in real time.
you'll need a cable hooked up to your laptop to view the data stream with the Ostrich.
when i started into prom burning, i didn't have a burner or a cable, so i went with the AutoProm.
the AutoProm handles chip burning, the Ostrich can't.
the Ostrich can be left in the car & can be ran in place of the chip without a laptop hooked up to it, the AutoProm has to have a laptop hooked up & running for it to replace the chip.
both do real time emulation.
if you don't have a burner or cable yet, you may want to look into the AutoProm.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
jaridjohn
Oct 5, 2015 07:01 AM
