I don't have a clue what I need
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Never had any experience with PROMs or anything, I have searched throught the archives for info though. I have nothing to begin "promming". I visited Moates and TunerPro websites. Can someone tell me what I need to get started? TunerPro, this is just the program, correct? I have a new laptop, more than the system requirements for thr program. I still need someway of connecting to the car? Do I plug into th ecm or Diagnostic port under steering wheel? Like I said , clueless, but very interested. Looking to LIGHTLY modify stock prom (L03 '89 RS). Thanks-
Car: 1989 Camaro RS
I've been reading for a while, do I need a programmer if I have Tuner Pro? Isn't that the programmer? Also, I tried to download TunerPro RT, but could not. Files Corrupted????!!?? I sucuessfully downloaded TunerPro though.
Car: Used to drive a camaro
You need a burner (I use Pocket Programmer 2), software to read/edit/implement the changes (TunerPro),and a communications cable to connect to your diag port under your steering wheel. You'll make a couple runs around the "hood", come back and review. Make your edits, burn, and rerun. Over and over and over and over until you get the results you deem acceptable.
Car: 1989 Camaro RS
thank you for help, Do I need a pocket programmer just to view engine data? Can I plug my laptop to a ALDL cable and adapter via USB? I'd like to learn my program and get numbers and things a while before I think about burning chips.
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
to see the data you need a program, I.E. winaldl, TunerPro or one of the others out there, & a cable that plugs in to your laptop.
the pocket programmer is for burning & not needed to get to the data steam.
Car: 1989 Camaro RS
Thanks guys, I'll get started data logging first, se how that goes, then maybe later start modifying my chip. Thanks for your help!
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
His OSTRICH works really well, too.
