first time tunercat
Old Feb 23, 2006 | 10:57 AM
wlk1020's Avatar
first time tunercat
This is the first time using any of this software. I have the rt program and need to know some anwers. First how do you know what injectors you have. Mine are gray on top. What tables do I tune for fuel. I have a mechanical ignition system so all I need to worry about is the afr. I have a large cam and vacuum is 14 at idle can I adjust the map table to compensate and again which table is it. I will have a million more questions to come so if you want to be elaborate that is fine. Thank you in advance
Old Feb 23, 2006 | 12:47 PM
brutalform's Avatar
Hello, and Welcome Aboard. Can you provide a bit more info? Engine, vehicle, mods, ECM? BTW, where in Pa. are you from?
Old Feb 23, 2006 | 04:15 PM
wlk1020's Avatar
This is a 91 corvette with a 8d definition file. It has a small block with a large cam,intake,throttlebody,headers,pistons,and I am told larger injectors. I do not know which size though is there a way to tell. They have a grey top on them thats all I can see of them. The owner also installed a mallory distributor and ignition system with mechanical advance that he does not want to remove. The factory ignition is completly disconnected. He wants to use this for race and he does not care about driveability.
Old Feb 23, 2006 | 04:16 PM
wlk1020's Avatar
I am in south east PA. York
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
