Tuner Pro and trans flags in 6E
Old Mar 1, 2006 | 07:43 PM
GWW's Avatar
GWW
Car: 89 Iroc-Z
Engine: 5.7
Transmission: 4 spd auto
I am confused on the transmission flags in Tuner Pro RT. I am running 350TPI Camaro, APYN chip, 700R4.
When I am scanning or logging the first gear flag always says false, third gear always states true, 4th gear always says false, overdrive requested always states yes. The only one that changes as I feel it should is park/neutral. Can someone provide some insight? I would think all of these would change as the transmission shifts or I change position of the shifter.
Old Mar 1, 2006 | 10:12 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
there isn't anything to tell the ECM what gear the trans is in other than a fourth gear switch, on my car i seldom see a change on it for forth gear, i believe its there mostly for the ECM to release the TCC just before the trans goes into overdrive.
Park/Neutral is just a switch, its either open or grounded.
the important things are TCC & that the ECM knows when the trans is in gear or park.
Old Mar 5, 2006 | 08:41 PM
GWW's Avatar
GWW
Car: 89 Iroc-Z
Engine: 5.7
Eureka! I found something
After some electrical sluething I found that the brake switch that deactivates the TCC was out of adjustment. Now the 4th gear states true when it goes into fourth, the TCC locks, first time ever!!!
The ECM commands what I think is some sort of lean cruize and the around town RPM droped significantly. Now if I could just figure our why warm open loop is such a rough idle. Anyhow one thing at a time. Thanks for your help!
GW
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
355tpipickup
Aug 19, 2015 10:02 PM
Exxon Limited
Aug 9, 2015 08:13 PM
