Need a bin for a 89 TA
Old Mar 12, 2006 | 07:43 PM
bonz's Avatar
Car: 89 GTA
I just got everything I need to start making my own chips. But I need a bin to get started. It is a 89 Trans Am GTA with L98. If I could get a stock bin that would be great.
THANKS
Mods. GMPP Vortec heads, Comp Cams XR269HR, Crane Gold Rockers, Hooker headers, SDPC intake manifold, free flow exhaust, Air Foil, TB Bypass, K&N filter. Future mods, TPIS Runners, AFPR.
Old Mar 12, 2006 | 11:45 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
get the APYU3516 from moates site, I had that in my -89.
(You can look at your stock chip and see what it says)
/N.
Old Mar 12, 2006 | 11:51 PM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
Transmission: T-5(for now)
Axle/Gears: 3.45 9 Bolt
I put an ARAP bin modified for an Fbody in an L98 Camaro and seen a huge increase in power,
I run my 305 with a heavily modified ARAP bin,
its a real good starting bin, but also works well untouched in a stock car
Old Mar 13, 2006 | 12:33 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
How much did it drop the 1/4 mile elapsed times?
Old Mar 13, 2006 | 12:39 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
ARAP is a very aggresive tune. You might need to lower the SA some to get it work.........
/N.
Old Mar 13, 2006 | 12:55 AM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
just did his car vs my car stuff
and seat of your pants,
Running 94 octane, and 190 fan turn on
Old Mar 13, 2006 | 01:04 AM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
/N.
wasn't bad pulled about 4* knock retard tops
94 octane though, got to love canadian gas
Old Mar 13, 2006 | 01:06 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Is it rated using the same method as U.S. fuels? A guy from Sweden was saying that they rate different than USA. So I am curious if Canada is different.
Old Mar 13, 2006 | 01:11 AM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
not sure but heard our gas is better,
I have got gas in the states and my car didn't seem to run as good,
this was awhile back, I used to run my 305 TPI with 9* base timing
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
beast94
Aug 20, 2015 06:44 AM
ezobens
Aug 19, 2015 10:29 PM
