To benefit others, please post about your cables/laptop
Old Apr 11, 2006 | 06:49 AM
SBNova's Avatar
Since I have been having this recent delemma with my old laptop, and the constant serial to USB problems that arise here and on other boards when laptops dont have a serial port, could everyone post what they use and what is working for them? Even if you dont have an adapter, please post your computer brand and speed, cable type (USB,serial and store bought/home made) -including the brand of adapter if using one, operating system and tuning software your running.
I think this could benefit anyone in the future who bothers to search for what works and what doesnt. Thanks
**Toshiba 430CDT 120mhz 16mb with a serial port to homemade cable using Tunerpro 4.0.
Old Apr 11, 2006 | 06:57 AM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
Toshiba Satellite 100CS - Pentium 75MHz, 24Mb ram, Windows 95, built in serial port
Works with TunerPro 4.00 for $8D aldl logging.
Old Apr 11, 2006 | 07:13 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
I use an Acer travelmate 2300 w/ Moates hardware and usb cables, but i am having a problem getting it to log for longer than 15 or 20 minutes. other than that it works ok.
Old Apr 11, 2006 | 07:47 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i have a new dell inspiron 6000 p4 2ghz 1gb ram, moates usb aldl cable, ostrich, and an lc1 with a generic usb - serial adapter off ebay, no problems with anything.
Old Apr 11, 2006 | 08:04 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Dell Inspiron = Old and like a Pentium II.(one serial and one USB port)
Use a serial and USB depending on the who/what/where
Mostly use TunerCat and Datamanster, but sometimes use TunerPro as well.
Use a Radiosmack USB adapter for the Romulator and no issues.
Other datalogging stuff is a Mabach(?) cable and I dont even remember what the other one is.
later
JEremy
Old Apr 11, 2006 | 11:33 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Sager Laptop, PIII @ 800 Mhz, 128 Mb ram, serial port & USB. Win98SE
Running AutoProm USB along with Serial logging on Comm 1 for other apps.
No problems once the setup is correct for the devices. USB always plays games until you get it set to be a specific comm #. 98 is not that smart
Also use a simple transistor cable to log my LG-4 with the serial as well.
Never finished making the LG4 XDF work in TP though (someday when it breaks again)
Jp
Old Apr 11, 2006 | 11:55 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
I run two machines, on and off, both thinkpads:
a 600E, 366Mhz, PII, running win 98. moates 8.52
a T21, 700Mhz(I think) PIII, running winxp, tunerpro, moates, and freescan (LT1).
I also had a 390E, very slow, not used for much right now. ran win98 and moates.
all of them use my version of a serial to ALDL adapter, custom PCB, mimics the design of andrew mattei or carston myers, etc, max 233 and extra diodes for 94-95 LT1 aldl interface.
works well overall. I notice in alot of cases the datalogging and connection is somewhat flaky, tuning on 87 IROC, '165 ecm at 8192, which is known to be difficult at times.
freescan on 1995 '8051 ecm seems stable. Not much tuning other than some statistics yet.
Old Apr 11, 2006 | 12:11 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Machine 1)
IBM Thinkpad 760ELD
100 MHz Pentium
48MB RAM
Windows 98 SE
Serial support
Parallel support
No USB
Andrew Mattei Serial ALDL interface and AutoProm serial work great
Machine 2)
IBM Thinkpad T21
700 MHz
256MB RAM
Windows XP SP2
Serial support
USB support
Parallel support
All interface hardware runs great
Marchine 3)
Dell Inspiron 9300
XP SP2
2.2 GHz P4
512MB RAM
No serial port
USB support
No parallel support
Machine 4)
Panasonic Toughbook (w/ touch screen)
400Mhz
(Don't remember RAM size)
Windows 98SE/XP dual boot
Serial support
USB support
Parallel support
All interface hardware runs great in both OS installations
Machine 5)
Home brew
Window XP
AMD X2 2.2Ghz dual proc
2GB RAM
nForce 4 SLI Mobo
Serial support
USB support
Parallel support
All interface hardware I own works great on this machine.
Hardware I own (all run perfectly on every machine with supported port):
Pocket Programmer II
Romulator I (x 2)
Flash n' Burn
Ostrich
AutoProm serial
AutoProm USB
AutoProm Bluetooth
ALDU1 USB ALDL interface
Andrew Mattei serial ALDL interface
Prominator Pro
DIY WB02
TechEdge WB02
Old Apr 11, 2006 | 12:47 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Dang, Mark, got enough gear there? LOL
I'm using a Del Inspiration
(1.4GHz, 512 RAM, serial and USB ports, no adapters required)
Mastech (eBay vendor) serial cable for datalogging
Ostrich for emulating on the USB port
I use both TunerPro RT and occasionally (not for a while) Datamaster for logging
Primarily use TunerPro RT for BIN changes since I'm beta for S_AUJP v4, used to use TunerCat
Old Apr 12, 2006 | 04:42 PM
SBNova's Avatar
Thanks for posting. I hope this helps people figure out options and connectivity in the future.
Old Apr 12, 2006 | 05:44 PM
elkabong's Avatar
Car: 84 Vette
Engine: 383 XFire
I am using a older Compaq Presario PIII 800 mhz with 512k mem and WinXP Pro. I use the Radio Shack Serial to USB converter and never have had a problem.
I also use my work notebook from time to time. IBM Stinkpad T40 I think.
Old Apr 12, 2006 | 09:42 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
Older CTX laptop 266mhz w/256 RAM running Win98. I had Win Me on it, but went back to 98. Tried to get Moates USB converter working, but no luck.
I use Scan tool and cable from EASE diagnostics, had that for a long time. Most ly use it for part throttle tuning and driveability.
Also last 2 years been running Tunerpro RT, with homemade serial converter/cable. Works good, use it for PE tuning.
I use Scan tool and cable from EASE diagnostics, had that for a long time. Mostly use it for part throttle tuning and driveability.
Last edited by MikeT 88IROC350; Apr 12, 2006 at 09:44 PM. Reason: Automerged Doublepost
Old Apr 12, 2006 | 09:58 PM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
Transmission: T-5(for now)
Axle/Gears: 3.45 9 Bolt
Dell something
Pentium M 1.73GHZ(533 FSB)
512 Ram
USB ports,
Moates Autoprom(I love it best investment I ever made, highly recommended)
Latest version of Tuner Pro RT,
works great fro datalogging/emulating/and burning
only wish I had bought a smaller laptop
Old Apr 13, 2006 | 08:10 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Mangus - your PC collection looks alot like mine. Makes for a small office.
Everything runs great on my X2 as well. Gotta love 'em.
Old Apr 13, 2006 | 12:31 PM
TierAngst's Avatar
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
Averatec 6100 series P4 HT w/ belkin USB to PDA(rs232) adapter and tunerpro.
Old Apr 13, 2006 | 07:18 PM
Scott T's Avatar
Engine: Justa three-fiddy
Transmission: t56
1.5 GHz Apple Macintosh Powerbook (mmm, PowerBook) running 10.4, Keyspan USB-Serial Adapter P/N USA-19HS (w/ DB-9 connector), running a datalogging program I've written (called ALDLx) in RealBasic that mimics the functionality of ALDLMon and WinALDL. When tuning, I use TunerPro in VirtualPC for programming a Romulator while datalogging through a second Keyspan. This is all for a '7730.
Old Apr 14, 2006 | 07:35 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Im running an HP Pavilion zx5000
It's a P4 northwood 3.0GHz w/ HT. 1GB Ram. Radeon mobility 9600 128mb. I use moates USB->Serial converter and ALDL cable.
Works great on my dads 730.
On my 165 it will just stop datalogging randomly, all the time, a real pain in the butt to get it going again. Gotta shut the car off and unplug/plug in the USB, run around in circles and pray to the datalog gods, etc.
Its Tunerpro RT software.
Old Apr 15, 2006 | 05:32 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
Fujitsu E Series E-6644/winxp SP2/built in serial and pcima socket I/O card
Datamaster TT
Datamaster cable
Old Apr 17, 2006 | 08:06 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
I'm using an IBM ThinkPad 240X (Celeron 450 MHz) running Windows 2000. I use Craig Moates' USB burner and a homemade "two transistor" cable connected to a traditional serial port.
I initially used Moates' DOS-based data acquisition software (which worked flawlessly, I might add), but it got to be a pain having to rely on a separate DOS boot disk to run the program and needing to reboot into Windows if the .bin needed altered. I now run TunerPro, which also works well but sometimes has issues connecting to the ECM. That was last year, though, so the new version might have corrected some things.
Old Apr 21, 2006 | 12:02 AM
Teeleton's Avatar
Car: 89 S10 Blazer
Engine: Built 4.3L V6 TBI
Transmission: Built 700R4
Axle/Gears: 7.65/Zexel/3.73
HP nc6000 w/ PentiumM & 1GB Ram. I've used both WinALDL, TunerPro, and PowerProgrammer2 with both Win2k and WinXP on it. Both times using an AKM OBD-1 cable.
Teeleton
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Strick1
Sep 6, 2015 02:21 PM
Strick1
Sep 6, 2015 10:38 AM
rsrookie
Sep 5, 2015 07:08 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
