$58 Base Timing Reference Angle
Old Apr 21, 2006 | 11:05 AM
HydraQuest's Avatar
Car: '87 Pontiac Trans AM
Engine: 350 CID STS Turbocharged
Transmission: T56 6-Speed SPEC Stage II
Running $58 on a repinned '730.
In the $58 the Reference Spark Angle is set to 0. Being a stock L98 w/reference SA set to 6, should the $58 reference angle be changed to 6? If so, would I need to change the Spark vs MAP table to compensate by adding 6 degrees to the whole table, or should I leave the reference angle to 0? When adding 6 degrees across the table it makes the timing look very aggressive. Just needing some direction...
Old Apr 21, 2006 | 06:04 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Set it to whatever initial timing your running.
It depends on what software your using. If you change the reference angle and see no change in the timing table, then you need to remember that it's not accounted in the particular software your using.
It's always good to set all the timing in chip to some constant amount, and then verify that with a timing light. Assuming everything is right can be dangerous.
Vintageracer
Jan 10, 2020 05:33 PM
z28_AJ
Aug 27, 2015 08:59 PM
Bstrang6
Aug 26, 2015 11:39 AM
Linson
Aug 21, 2015 02:12 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
