Spark timing at cold
Old Apr 19, 2006 | 10:06 PM
ULTM8Z's Avatar
Somehow the ecm is cutting out about 15 deg of timing at cold temps in open loop. But my base coolant advance correction vs coolant table is stock AUJP. What other tables would affect this?
Any thoughts?
Old Apr 20, 2006 | 05:27 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
There's the "Spark Advance Base Temp. Correction Table Bias" that will offset the spark advance, so that the table "Spark Advance Temp. Correction vs. Load vs. Temp" gets cancelled.
There's also a "Spark Advance Cold Disable Temp." that should disable the use of the two items mentioned above.
I don't know what "Spark Retard Hot Disable Temp." does.
I don't think 8D has any other "catalyst heating" algorithms in it, but I could be mistaken.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Bryan F
Aug 18, 2015 02:28 PM
