about new cam
about new cam
I am have just finished installing my motor and need to know if I will need to modify my computer to make the car run with this cam
Notes from jegs: Best Cam for 350 TPI with modified computer.
Operating Range: 1800-5800 RPM
Duration Advertised: 268-4° Intake / 276-4° Exhaust
Duration @ .050'': 222° Intake / 226° Exhaust
Valve Lift w/1.5 Rockers: .464'' Intake / .464'' Exhaust
Lobe Separation Angle: 114°
it is a 91 z28 350 tpi and what will happen if I do not modify the computer
thanks for any help
thanks for any help
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
ITs gonna blubber and run rich at idle and lower rpm;s and you'll prolly see some surging.
SD doesnt like cams, especially when u start shoving large ones in there.
Your going to have to investigate tuning.
Stickies up top are an awesome place to start learning.
later
Jeremy
later
Jeremy
