ways to increase idle?
Old Apr 28, 2006 | 08:54 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i need a way to increase my idle, for setting my tps, the only way to get 100% at wot is to have about 7% at closed throttle. i can readjust the throttle body screw so the tps gets down to its .54volts or .2% throttle. but when its like that. the engine just doesnt get enough air for idle. what can i do to fix this issue? can i increase timing at the 0-1000rpm ?
Old Apr 28, 2006 | 11:04 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Get the motor to idle nice by the mechanical screw and then reset the TPS to .54.
Then do the reset on the IAC just to be sure everything is ok ans then see by logging with motor off if the stroke on the TPS is better.
Might be the stroke of your foot is not actually opening the throttle all the way. Try it right at the TB and then by foot to see the difference.
Old Apr 29, 2006 | 01:19 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
right at the TB is where ia lways check tps voltage. and with the tb screw adjusted enough to keep the car running, and tps set at its .02% . at wot at the TB, it reads roughly 85%
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
forstral
Aug 19, 2015 03:20 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
