Super_8dm2 extended upper VE table question?
Old May 8, 2006 | 09:23 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
I have the super_8dm2 definition file with a AUJP bin. Currently the values are all zeros in the extended tables. Can i just fill them with the appropriate values, and set all the values in the original table to zero? Will that work? Any insight to this matter would be appreciated, i could not find any direct answers.
Old May 8, 2006 | 10:26 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
You need to install the patch to make it work in the bin. Then the table would be active. The original upper table goes to 5600, the new one goes to 6400 but is in a different location. The patch installs the table and the redirection address so the code can find it.
The patch is around somewhere...
Got it
https://www.thirdgen.org/forums/diy-...ht=extended+VE
Old May 9, 2006 | 08:53 AM
69 Ghost's Avatar
Car: 69 Camaro
Engine: LS1 converted to LS6
Transmission: 4L70
Axle/Gears: 12bolt 3:42
I have a Super_8dm.XDF that includes the new table as well as the old extended table and WBO2 stuff along with the conversion cleaned up from XDF to ECU. I have sent this to Mark and Craig but don't think they ever put it on the sites. I can email you the latest copy. Just email me.
Old May 10, 2006 | 12:23 AM
69 Ghost's Avatar
Car: 69 Camaro
Transmission: 4L70
XDF's sent. If I missed anybody let me know.
Old May 10, 2006 | 10:53 AM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Thanks, but for some reason it won't open.
Can you please resend thanks:
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
