need help :( noob
Old May 26, 2006 | 05:16 PM
89_fireform's Avatar
Car: 89 WS6 formula firebird
Engine: 305 TPI :(
need help :( noob
i just bought the burn1 and gp1 or w/e from moates. and ive read things and all that, but im at a loss, i need someone 2 really help me with this, i need something with an easy to use interface, maybe i need a new program, but this sucks and im wanting to sell it all already and i havent had it for 3 hours.i dont under stand this "bin" but i believe its some sort of baseline file? but were do i get one? that fits my lb9 2.73 axel ratio, i probly need someone on yahoo,aol or msn messenger to help,
Old May 28, 2006 | 08:20 PM
Engine: 305 TPI :(
up for no advice.
Old May 28, 2006 | 09:45 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
Explain a little more about what you are talking about. ALso if your talking about ur scanner your in the wrong board.
Old May 28, 2006 | 10:32 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Take a deep breathe, and relax.
There's an steep intial learning curve.
Try slowly rereading the stickies, then ask questions. The basics have been covered so many times, that you just gotta take it on yourself to do the intial reading. Once you get some of the basics down, then it'll start to make sense.
Old May 31, 2006 | 10:11 PM
Engine: 305 TPI :(
well its starting to make sense. but im hearing about VATS? and i must disable it? what and how? and i heard about offsets? which do i use?
Old Jun 1, 2006 | 07:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You shouldn't have to worry about VATs as the '89s have it. Just to double check this look at your ignition key, it will have a small black thing in it with a contact on each side. That is what the VATs module reads.
As for offset your BIN is a 16 KB. Head over to moates.net and down a little on the left side. There is a link to a little chart of offsets. Pick your BIN size and the chip you are using for the proper burning offset.
RBob.
Old Jun 1, 2006 | 02:03 PM
Engine: 305 TPI :(
ya ok i got the chip in my key, ive got the bin and all that figured out, but now my car wont start with thie chip, i hear the fuel pump loudly, and it wont stop, its like drowning my car, the car turns over like normal but it wont idle
Old Jun 1, 2006 | 04:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I'm not sure of what you are saying. It won't start, then it won't idle.
An important test is to watch the SES light at key-on (do not crank the engine).
At key-on the SES light should come on briefly, blink off, then come on solid. If it doesn't come or, or it doesn't blink off, then the ECM is not running from the chip.
Also, at key-on engine-off the fuel pump should only run for 2 seconds then stop. If the FP keeps running then either there is a wiring issue, the oil pressure override switch is bad, or the ECM is bad.
RBob.
Old Jun 1, 2006 | 08:52 PM
Engine: 305 TPI :(
well, i will test and tell you what happens on friday, but the ecm is working, i can take out the moates adapter and chip and use stock prom, car runs and drives normal. but when i put in the chip/adapter it acts up.
Old Jun 2, 2006 | 10:23 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
You might just want to re-burn the chip, sometimes they don't program cprrectly (rare, but it happens). What differences are there between your stock prom and the burned chip?
(FYI - you can use TunerPro to show you the differences in them)
Old Jun 2, 2006 | 12:43 PM
Engine: 305 TPI :(
i want a stock bin file, im using APYP 6E is this fine?
Old Jun 3, 2006 | 09:14 PM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
Transmission: T-5(for now)
Axle/Gears: 3.45 9 Bolt
not really, you need to change your injector constant,
plus change the cooling fan input,
also you should really log your car cause thats an aggressive bin for your 305
just noticed your auto, thats a stick bin, ARAP would be a better starting bin,
Old Jun 3, 2006 | 11:04 PM
Engine: 305 TPI :(
set them to what?
Old Jun 4, 2006 | 12:11 AM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
set them to what?
better start researching,
I read stuff in here for about year before I bought my chip burner and I'm still a rookie by far,
takes alot of reading and learning
start comparing 350 and 305/ camaro and corvette bins, find out what different stuff means
Old Jun 4, 2006 | 03:32 PM
Engine: 305 TPI :(
ok my stock prom has a sticker says "delco APYR 3506" when i burn apyp or arap 6e i dont hear my fuel pump? switched the VATS on and off? what now?
Old Jun 4, 2006 | 04:46 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Either the ECM, the FP relay, the chip/MEMCAL adapter, or the wiring is foo___.
VATS has nothing to do with the FP running at key-on.
RBob.
Old Jun 4, 2006 | 05:09 PM
Engine: 305 TPI :(
NM I fixed it! thanks but how do i change injector flow
SonWolve
Convertibles
24
Mar 1, 2006 08:32 AM
Randy92Z
Sep 6, 2004 11:54 AM
cormyr
Aug 10, 2004 11:00 PM
ajbutowicz
Jul 2, 2004 04:15 PM
