I need help please.... Begging here.
Old Sep 11, 2000 | 10:40 PM
NewYorker's Avatar
Here is my situation... I am recently jobless and I found out that the place that does the custom prom burning wants $350 to do the work. Well obviously I don't have that. So, here is what I am asking.... Can someone here please burn a chip for me? I am going to post this at Thirdgen also, but I am desperate. My inspection is up in 10 days and because it is running sooo rich it will not pass. I tried today. Anyway, I dont know what else to do. I can get any info that is needed to make the right chip, but I need help here... please. Otherwise "Chance" will have a spot in the driveway and I wont be around for a while.
Thanks guys...
Sherry
"Carpe Diem"
NewYorker:The one with the funny accent
1988 Trans Am, Nicknamed "CHANCE" 355, TBI. White w/Red Interior, Digital Dash, Black Crosslace Wheels
"Chance"
NewYorker88TA@nycmail.com
One of the founders of the INFAMOUS NE Crew.
Old Sep 11, 2000 | 10:53 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
no one can program a chip for your ecm unless you call a company like jet ( i believe they are the only ones who can do the 8063)
so, sorry. Your car shouldnt be running SO RICH with such a mild 350 anyways, do you have a catalytic converter? what is your timing set at? which injectors are you running?
Old Sep 12, 2000 | 05:16 AM
Thorlis's Avatar
Have you tried lowering the fuel pressure?
Old Sep 12, 2000 | 10:09 AM
NewYorker's Avatar
Pablo, the car is running rich because the car is now equipt with cop car injectors and this is why it is running too rich. It has the wrong ecm chip for this setup and its putting out way too much pressure on these injectors. If you can help with this, then I would appreciate it..... i.e. burning new chip, otherwise, dont worry about it.
Old Sep 12, 2000 | 02:50 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
take out those injectors and put the 305 injectors in there
Old Sep 12, 2000 | 02:52 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
btw i just said no one can program a chip for that ecm unless someone came out with an ecu file i dont know about
Old Sep 12, 2000 | 03:00 PM
FastBroker's Avatar
Hi, Pablo, I was they TBI board guy looking for 65pph injectors. Are his COP injectors the ones I need? If so, I would graciously swap him for my 55's, if he can use them??? I hop eI'm not waaaay off, here. I will overnight, if you need them quick...
Old Sep 12, 2000 | 03:03 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
those would be the 65 lb injectors .. btw Shes a She
I still dont think you need those injectors though Fast
Old Sep 12, 2000 | 03:07 PM
FastBroker's Avatar
Sorry, NewYorker... My bad.
Pablo, if my 55's will help her, I would gladly swap... Do you think it makes sense for her? comment NewYorker???
Old Sep 12, 2000 | 03:27 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
i think she definately needs to go with smaller injectors. If i were her i would just reinstall the 305 injectors seeing as how her prom calibration is setup for them and fast if you are lean across the board why dont you just increase your fuel pressure?
what type of setup do you run? I have a fairly modded 305 that is probably in the mid 14s with the stock 305 injectors at 17 psi and a custom chip and it doesnt lean out at all on me
Old Sep 12, 2000 | 03:33 PM
FastBroker's Avatar
350, generic 214/224, .442"/.465" cam, head porting, 2.5" dual exhaust w/x-over, stainless vette "headers", 3 chamber Flow's, Performer intake w/custom adapter, about 9.75:1 CR, balanced, pink rods, steel crank, 4-bolt crate motor block, 4:11 gears. In TBI forum I said why I don't want to raise the FP, works a little but too many negatives for me...
Old Sep 12, 2000 | 03:39 PM
NewYorker's Avatar
Hey FastBroker.... they are 58 Pound fuel injectors I believe. The ECM right now is set up fir a 305tbi and the injectors are too large for it.
Pablo, I dont have the old injectors, I already asked Jaymie if she can send them to me and its in the works... but ultimately I will need that Prom...
FastBroker, Let me know if you can help here..... I can get you whatever specs you need. My email addy is in the sig... let me know what you need!
Sherry
"Carpe Diem"
"Chance"
Old Sep 12, 2000 | 03:44 PM
FastBroker's Avatar
I need:
65pph injectors. I think Pablo believes yours a 65??? Maybe you can put up injector paint colors and/or part number so we can find out the pph??? I'll buy them off of you if you don't need/want them and they are what I need, if that's ok? Oh, I need a picture of you, too. Heee, heeee. Thanks for trying to help!
Old Sep 12, 2000 | 03:49 PM
FastBroker's Avatar
Oh, Pablo, about the fuel pump wear in my TBI post from raising pressure, I think my Airtex pump is only rated for 16psi regulated flow. Of course you can go more, but trust me, it'll be another $100 for a new pump in far less time than if you ran at only 11-13psi. What pump do you have? Aftermarket in-tank? I am running external. I'm funny about wires in gas/gas vapors... Plus, I like the noise for some reason.
Old Sep 12, 2000 | 04:58 PM
NewYorker's Avatar
FastBroker, the injectors are installed in my TA and they were never for sale. Im sorry about that....
I dont know what to tell you about the ECM. I still need a chip and I'm going to have to get it pretty fast. I'm going to see if I can get some input from Jaymie and Rich who installed them for me. They are 58lb injectors..... Pablo has never seen my car.
Also FastBroker, I am seeing someone... so sorry... No picture.
Old Sep 12, 2000 | 06:12 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
you are right i have never seen your car
but ive seen you say on numerous occasions "Cop car" injectors
cop car injectors are 65 lb injectors, yellow/brown stripe, end of story
and like i said 5 times allready, there is no ECU file available for your ecm. In english, you probably wont find anyone to program a chip for you because its likely no one can! The only company IVE heard of that will write a calibration for the 8063 ecm is JET. Ive seen no commercially available prom editor that has an 8063 definition file (thats like the 'decoder ring') But if you want to keep trying, by all means
[This message has been edited by Pablo (edited September 12, 2000).]
Old Sep 12, 2000 | 07:19 PM
RichS's Avatar
Sherry, your injectors are 65lb. And I believe that the car will run better with the stock injectors in there.
Old Sep 12, 2000 | 08:34 PM
NewYorker's Avatar
Thank you Rich. I asked Jaymie today if she could mail them up ASAP so I can do the inspection. I'll see you guys soon... as soon as my friend Ron is ready to drive his vette up there.
Old Sep 13, 2000 | 12:46 AM
Dan W's Avatar
ADS Superchips can also do chips for the 8063
Old Sep 13, 2000 | 07:55 AM
FastBroker's Avatar
I'm trying to figure out why your engine is even running rich for an emmissions test??? Isn't the test taken when the ECU would be in closed-loop??? The ECU should "fix" any potential rich condition. The computer BLM values will be low (below 128) which would tip-off a spart tech that you have bigger injectors in there or some other enriching problem but if they are just looking at tailpipe emmissions, your tailpipe emmissions should be ok in the closed-loop conditions of the test, right???????????? You would be rich ina cold-start situation but I don't think any state does that, yet...
Oh, I'll make the offer again, it sounds like your injectors are too big for your motor. Yes, a chip could fix that but it sounds to me like you could just install your orig injectors and be done with it. Up to you, I guess...
[This message has been edited by FastBroker (edited September 13, 2000).]
Old Sep 13, 2000 | 09:49 AM
Brent's Avatar
The Ecm can only compensate 10% for rich/lean conditions. 45lbs/hr to 65lbs/hr injectors is a 30% increase in fuel. Not to mention the calibration in the 305 prom is off, which further compounds the problem.
Actually the stock injectors will be too small if they are run at stock pressure. They stock 45lbs/hrs are good for max of 180hp. Unless the cam is very small her 350 should breath enough air for 210-220hp.
Her car may run OK part throttle and cruise, but WOT will be lean.
Old Sep 13, 2000 | 10:02 AM
FastBroker's Avatar
OH, That explains a lot. I thought 55's were OEM for 305, sorry. Sounds like her 45's and her 65' won't work, right? I have the 55's she can have if I can have her 65's. Pretty fair trade, I think, no?
I am using a 1227747 ECU and it can correct much more than 10%. Which ECU only corrects max of 10%??? That doesn't sound like much correction but if it's 10% max, those 65's have to go, I guess.
Fanatic1074
Oct 3, 2022 05:57 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
LC2 TECH
Oct 13, 2015 11:53 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
wstephan96
Sep 25, 2015 04:28 PM
