NEED TO KNOW ABOUT THIS ECM!!!
OK, I bought it, hoping it is a TPI SD ECM... I dunno how to check, it was REAL cheap, so either way, it doesnt matter.
Hers the number off the case:
1228746379
THANX!
1228746379
THANX!
Sorry, the 1228746 is a TBI ECM.
you can look here for future ecm lookups.<cr> http://www.cruzers.com/~ludis/
THANKS BRENT! Next question:
Does this ECM have VATS in it? If so, what can I do about that? It might be going into an 88 TA with a 355 TBI, the engine is newer than an 88. Have any ideas if it will work?? And does anyone know how to identify harnesses? Thanks All.
Axle/Gears: 3.45, 3.27, 3.27
Yes it is a VATS ECM. Read the other post on TBI non-VATS for the correct chip number for it. Brent, question for you. I picked up a 127730 ECM. I went to your link, but it doesn't show up on the list. I was told it is for a 90-92 TPI. I picked it up because I was planning a conversion from TBI to TPI. What is it? TIA, Lon.
Thanks Brent. I found it now. Yes it was a typo.
efiguy
Sep 27, 2015 01:30 PM
