Ostrich question
Old Jun 13, 2006 | 09:32 PM
DIABLO NEGRO's Avatar
Car: 1985 project SC
Engine: LSX (planning stages)
Transmission: (planning stages)
Axle/Gears: (planning stages)
Ostrich question
i know this has been asked before but i cant find the post. with the Ostrich how does it work do i need to keepit in the car or do install a flashrom and upload to the ecm or what ??? thanks
Old Jun 14, 2006 | 02:24 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
You edit & load the bin from a PC with Tuner Pro RT to Ostrich, and then run the car off of Ostrich.
Ostrich is a PROM Emulator only.
Old Jun 14, 2006 | 01:38 PM
so then i would tune to the desired spec with the ostrich and burn that prom right?
Old Jun 14, 2006 | 03:57 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
You can install the Ostrich permanantly (just like the Prominator). No need to burn chips, etc. It's always recommended that you carry a known-good chip in your vehicle, however, regardless of the hardware you're using.
Old Jun 14, 2006 | 04:29 PM
mnorton's Avatar
Engine: 305 LB9 TPI
Once you decide that the car runs well enough, you can burn a PROM, then remove and sell the Ostrich. Of course you will need to buy a PROM burner too.
Old Jun 14, 2006 | 04:31 PM
Mangus's Avatar
Transmission: T5WC
To be cleear, burning the PROM is optional. If you're like me, the car never runs well enough, since there are always changes to be made and new parts being swapped in.
Old Jun 14, 2006 | 04:57 PM
DM91RS's Avatar
Car: 91 RS
Old Jun 14, 2006 | 05:07 PM
ok fair enough but i figured i could tune both my camaros with 1 unit but u are right once i start tuning u cant stop
Old Jun 14, 2006 | 09:56 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
